Old 09-30-2019, 05:09 PM   #1
TwoFistedJustic
TwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the rough
Default S-Series Motor Mounts - Optimized order of replacement
I originally posted this on SixthSphere about a year ago. Posting it again here.
This is the order I came up with to replace engine/transmission mounts on my 2002 SC2 with the least amount of work. Please comment or correct if you see any issues.
Remove the upper dogbone (LH side, just under the battery tray).
Remove and install the transaxle mount. (the stubby one between the transaxle and the frame)
Install the upper dogbone.
Remove the upper motor mount. Place the new mount on the studs, but do not put the nuts on yet.
Remove and install the lower dogbone (RH side). But do not tighten the bracket nuts from beneath yet.
Put the five nuts on the motor mount and tighten.
Tighten the lower dogbone bracket nuts from beneath.
Done.
TwoFistedJustic is offline   Reply With Quote
Old 09-30-2019, 05:27 PM   #2
RobertGary1
1996 SC2
Default Re: S-Series Motor Mounts - Optimized order of replacement
I think its easier to do the lower mount with the dogbones left in. As you lower the car the tranny moves right back into place to align the mount. Otherwise you have to muscle it around a bit.
-Robert
Old 09-30-2019, 07:44 PM   #3
Zeebins
Zeebins's Avatar
Depending on if you have a manual or automatic, the trans mount may be kind of a pain to gt out. I'd do them in the order you said
97 SL2, auto, 118K miles
Old 10-02-2019, 01:19 AM   #4
TwoFistedJustic
It's true about the automatic transmission mounts. They are more difficult. A lot more difficult. Though if I recall correctly, there is a trick to it, which I infer because it wasn't going in, wasn't going in, wasn't going in, wasn't going in, then suddenly it was in and I couldn't tell you how. So there's a trick. I just don't know what it is.
Old 10-02-2019, 08:31 PM   #5
Zeebins
Zeebins's Avatar
When I did mine I ended up putting a second jack under the engine and i removed the top motor mount bolts to raise the whole thing some more. A crow bar helped some here too
engine mount, frownie, motor mount, transmission mount
Replacing all four motor mounts over a few months - does it matter what order? Upstate Saturn S-Series Tech 3 11-03-2014 11:07 AM
Motor mounts replacement npereza5 Aura General 1 10-18-2013 03:45 PM
L-series motor mounts? Dang L-Series General 7 03-28-2008 01:18 AM
WTT: SPS Motor Mounts for Stock Motor Mounts soccer69er Classifieds 1 10-28-2004 07:13 PM
Motor mounts for L-series Qlara L-Series Tech 4 05-31-2002 07:16 PM
