Old 03-30-2014, 11:12 PM   #1
09_enrique
09_enrique is on a distinguished road
Default Radio with aux
I have a 2004 saturn ion 2 and I'm trying to get a new radio for it. I don't want an aftermarket stereo because I think it will look weird. I was looking into other saturns and I saw that a 2006 saturn ion 3 radio has the aux thing. Will that radio fit in my car?
09_enrique is offline   Reply With Quote
Old 03-31-2014, 06:19 AM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Radio with aux
It a not an "aux thing", it's an auxiliary input, and no, it won't work.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 03-31-2014, 06:24 PM   #3
picaman
picaman is on a distinguished road
From what I have read, the 2004 Ions have 1.5 DIN radios and the 2006 Ions are double DIN.
picaman is offline   Reply With Quote
Old 03-31-2014, 07:26 PM   #4
NickL30
NickL30 has a spectacular aura aboutNickL30 has a spectacular aura about
NickL30's Avatar
2004 ION-3 Quad Coupe
Do you have xm capabilities in your car? If so then you can splice right into the xm harness in the back of your stock stereo for an AUX input with the help of this helpful tutorial. I do not have the 6 disc cd changer in my 04 and it still works. I was also going to try to see if just having the AUX signal from the device will work so then a person would only need the plug or wire it directly to the pins on the back.
http://www.redlineforums.com/forums/...radio-yes.html
NickL30 is offline   Reply With Quote
Old 03-31-2014, 07:59 PM   #5
2006 ion2
2007 ION-2 Sedan
The hole is different, but more importantly, afaik, the harness is different.
2007 Saturn Ion 2
Old 03-31-2014, 08:09 PM   #6
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
All 2000 and newer Saturns have a double din radio opening. The 2006-2007 Ion radios may fit older Ions with some minor alterations to the dash and wiring changes, but they are definitely not a "plug & play" swap.
I say it may be possible because another forum member was able to install a radio from a 2007 Ion in a 2002 Saturn SL2 (link here). The 2000-2002 S-Series and 2003-2005 Ion both use the exact same radio mounting scheme. The 2000-2005 L-Series and 2002-2005 Vue also use this same mounting scheme.
This mod only works with the 2004-2005 radios that say "MP3" on them. A factory-installed XM radio tuner is also required because the tuner communicates with the radio through a data connection and the ability to select the XM1 and XM2 modes via the AUX button on the radio is only enabled when that connection is present. These modes can't be selected if an XM tuner is not connected to the radio.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles
2018 Chrysler Pacifica Touring L 48K miles
Old 03-31-2014, 09:11 PM   #7
Dutchman1954
Dutchman1954 is on a distinguished road
2004 and 2005 Ions used the same radios, and as I recall one of the options was a unit with a mp3 jack. They were bigger than the standard unit, you'll lose the little shelf under the current radio.
Dutchman1954 is offline   Reply With Quote
Old 03-31-2014, 09:16 PM   #8
ruley73
ruley73's Avatar
They did not have an mp3 jack. They could only play mp3 files from a CD.
Old 03-31-2014, 10:04 PM   #9
NickL30
NickL30's Avatar
Well there goes my plan to see if it works with just the AUX plugged in.
Old 03-31-2014, 10:15 PM   #10
NickL30
NickL30's Avatar
I really like the idea of a newer stereo in my Ion like one from an 06 or so. That looks like it would be fun.
Old 04-01-2014, 08:55 AM   #11
09_enrique
What would be a good aftermarket stereo for a 04 saturn ion?
Old 04-01-2014, 06:04 PM   #12
picaman
Thanks for clarifying that. Indeed, you can install an aftermarket double DIN radio.
Thanks for giving me back my next weekend. My radio has MP3 and the AUX button, but apparently not the XM tuner as the button does nothing when pushed. I'm sure I'll find a new project.
Old 04-01-2014, 07:57 PM   #13
ruley73
ruley73's Avatar
It depends on what features you want and what you're willing to spend. I would say you get what you pay for, but that is way less true now than it was ten years ago. Nowadays, as long as you stick with one of the more popular brands and don't get the least expensive models, the quality and features don't vary as greatly with price as it used to.
I just wish one of those big companies would design a radio that is easy to use and allows you to make minor adjustments while driving without being too distracted. My ideal radio would have a layout simlar to the 2006-2007 Ion MP3 radios. I really like the six multi-purpose buttons and two knobs that those radios have.
Old 04-01-2014, 09:26 PM   #14
NickL30
NickL30's Avatar
Does anyone know if it would be relatively easy or not to install an 06-07 stock stereo from an Ion or Vue into an 04? I figured if I found the diagram for both cars that it would be pretty easy but haven't seen anyone else do this except for the link on this page to an S series.
Old 04-08-2014, 10:49 PM   #15
peepsion
peepsion is on a distinguished road
2004 ION-2 Quad Coupe
I swapped out the radio in my 04 with one from a 03 ion, that had an am/fm, cd and cassette player in it. I use a cassette player adapter for my ipod. The 03-04 radios were not plug and play exactly I had to buy a special wire harness from the dealer that made it plug and play. I liked it because it was cost effective at $35 for the radio and the harness and it kept the factory style radio.
peepsion is offline   Reply With Quote
radio upgrade with aux
Switching out the radio with a Pontiac black radio pbmax Aura General 9 05-15-2011 01:34 PM
Can I replace my 01 SL1 CD/Radio with a newer GM Stock radio? SuperCujo S-Series General 46 01-27-2009 10:13 PM
96 SL SOHC radio wire to light on clock/radio turner dddaaa S-Series Tech 1 06-21-2008 04:53 PM
Need factory radio harness/plug for SAAS CD/Cass/FM/AM radio JButler1983 L-Series General 2 12-03-2006 05:48 PM
'05 Radio Wiring Harness for Aftermarket Radio Crawdaddy Ion General 16 05-12-2005 01:33 AM
