Old 05-15-2007, 10:06 AM   #1
Boodah
Boodah is on a distinguished road
Default 98 SL2 clutch hydraulic system
I've got a 98 SL2 manual transmission and I'm experiencing the classic clutch hydraulics problem. I've read in a few places replacing the master and slave cylinders isn't such a bad job but I've also seen a couple of posts from people saying if you have cruise control and ABS (I have both) you have to adjust them after you replace the master and slave cylinders. Is this true?
Boodah is offline   Reply With Quote
Old 05-15-2007, 11:16 AM   #2
BarnOwl
BarnOwl's Avatar
2000 SW2
Default Re: 98 SL2 clutch hydraulic system
Cruise control doesn't have any affect on the job. All the cruise control components are in the cabin. With ABS you have to loosen the brake master cylinder bolts and pull the brake master cylinder out of the way to get the clutch master cylinder off. After you're done tighten the bolts back up. Other than that it's the same. If you want to be certain it's the hydraulics and not the clutch components, here's a thread that shows how to test it.
Old 05-15-2007, 01:40 PM   #3
DonP
What BarnOwl says!
Q about hydraulic clutch system MikeNW S-Series Tech 13 12-22-2011 09:11 AM
Bleeding clutch hydraulic system MikeNW S-Series Tech 2 06-03-2009 01:43 PM
More on clutch hydraulic system fixing... jcw S-Series General 2 01-25-2009 02:04 PM
Clutch Hydraulic system for sale MikeNW S-Series Tech 0 05-18-2008 11:44 PM
Clutch hydraulic system problems clemtwist S-Series General 4 04-03-2006 08:31 PM
