Old 12-04-2019, 12:32 AM   #1
Rez
Rez is on a distinguished road
1996 SW2
Default P303 code with exhaust smell
Hey, everyone. I noticed a little while ago that my idle was somewhat erratic. Not too long after I started my car one day and it started stumbling really bad and threw a blinking CEL. Whenever I hit around 30-45 mph there was very strong shaking, but if you gased it it went away. I got the CEL read and it showed a P303 code. I replaced the IAC, the plugs (#3 was very black), put on new wires, a new coil pack on #3 and still a code - replaced the fuel injector as well and no luck.
I checked the new plug on my 3rd cylinder today and it was already black on the ceramic after a day - maybe too much fuel is fouling it? When I ran the heater on the way home I noticed a smell in the cabin (smelled somewhat like exhaust). I'm trying to narrow my problem down and I can't really tell if this is an exhaust leak issue or a fuel issue or what. I can't keep throwing parts at it with the holidays right now. I haven't checked for exhaust or air leaks yet and I have a compression tester I'll use tomorrow, but given what I've told you I'm looking to get some ideas. Thanks!
Rez is offline   Reply With Quote
Old 12-04-2019, 09:14 AM   #2
BV22
2002 SC1
Default Re: P303 code with exhaust smell
Cylinder 3 is the most common one to burn a valve on the DOHC engine. This results in a severe loss of compression in that cylinder with accompanying misfires. The compression test will tell you if that is indeed the issue. Look up OldNuc's procedure for doing the compression test.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 12-04-2019, 11:07 PM   #3
Rez
1996 SW2
Well, not what I was hoping for. All cylinders are to spec, except #3 - 0 compression. What options do I have with this except for a valve job or engine swap?
Old 12-05-2019, 09:54 AM   #4
BV22
2002 SC1
Options are few. The head needs to come off and be rebuilt or replaced with a rebuilt or used head.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 12-05-2019, 11:40 AM   #5
I had the machine shop rebuild my head as well as doing all the other machine work. Came out great.
P303 Code with No Start Onionknight S-Series Tech 22 01-07-2018 05:32 PM
SES code 45, rough idle, exhaust smell dennis S-Series Tech 22 06-20-2006 11:28 AM
Exhaust smell L100 L-Series General 0 06-11-2006 06:24 PM
Rotten egg smell from exhaust SLAPSHOT Vue General 8 01-05-2006 09:57 AM
Exhaust smell.... HookedUpSL2 S-Series General 3 02-23-2004 12:47 AM
