Old 12-23-2008, 12:31 PM   #1
2003MercMaraude
2003MercMaraude is on a distinguished road
Default 2001 SL2 auto trans into 1993 SL2
Will a 2001 SL2 auto trans drop into a 1993 SL2 with no problems? I know that for regular GM's the auto trans's like the 4T60E were very year-specific because certain years used PWM TCC lockup, some didn't, ratios changed, etc. I didn't know if I would be facing similar compatibility problems with my 1993.
Thanks
Steve
Rides:
2004 Ford Taurus SEL
2003 Mercury Marauder
1988 Chevy K1500
1976 Pontiac Firebird
Add to 2003MercMaraude's Reputation
Rate the quality of this post and help 2003MercMaraude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2003MercMaraude is offline   Reply With Quote
Old 12-23-2008, 01:04 PM   #2
Default Re: 2001 SL2 auto trans into 1993 SL2
Ratios are different.
http://www.differentracing.com/tech_...gearratio.html
Old 12-23-2008, 01:48 PM   #3
2003MercMaraude
According to those charts the gear ratios for the two year range MP7's are the same but the final drive is different. Crap. It would probably work but the speed signal to the PCM would be wrong. Thanks
Steve
Rides:
1988 Chevy K1500
Old 12-27-2008, 07:58 PM   #4
BarnOwl
BarnOwl's Avatar
I'm pretty sure the gear ratio is not the thing to worry about. I put a '97 auto trans in a '98 and it worked fine despite the different gear ratios. However, an 01 transmission will not swap into a '92. As I recall, '94 to '02 will swap. '92 from a certain vin will swap to a '93. '92 to that vin swaps with a '91.
Add to BarnOwl's Reputation
98 SL2 Auto Trans has clunking sound when Trans shifting gears C130Flyboy S-Series Tech 5 01-29-2008 01:58 PM
1993 SL2 manual trans questions juspay4speed S-Series Tech 1 12-09-2007 09:52 PM
1993 SL2 auto w/ AC PCM schultp Classifieds 0 04-29-2006 05:42 PM
2001 SL2 Auto trans Won't Shift into Drive. Speedyox S-Series Tech 7 03-20-2006 02:42 PM
"2001 SL2" Auto. Trans. ? danielwau S-Series Tech 2 01-18-2001 11:22 PM
