Old 06-13-2007, 02:15 PM   #1
STRNFAN93SL2
STRNFAN93SL2 is on a distinguished road
STRNFAN93SL2's Avatar
1997 SW2
Dizzy Wiring Trunk Latch Assembly from 98 SL2 Into 95 SL2 - Need Help
Hello,
I'm planning to add keyless entry with electronic trunk release on my 1995 SL2 so I went to the junkyard and pulled the trunk release assembly (with actuator) from a 1998 SL2. I'm not sure how to hook up the switch that controls the cargo light in the trunk.
The wires on the 1998 trunk assembly are as follows:
An electrical connector containing 3 wires
1 black(I presume is ground)
1 gray (that's the trunk release actuator)
1 red/black that leads to the switch controlling the cargo light
An electrical connector containing 1 wire
1 black wire that attaches to the metal frame of the trunk assembly.
The wires that come from the 1995 SL2 domelight are as follows:
An electrical connector containing 2 wires
1 orange
1 red/black
Any help would be greatly appreciated
Thanks in Advance!!
Add to STRNFAN93SL2's Reputation
Rate the quality of this post and help STRNFAN93SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
STRNFAN93SL2 is offline   Reply With Quote
Old 06-13-2007, 03:12 PM   #2
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: Wiring Trunk Latch Assembly from 98 SL2 Into 95 SL2 - Need Help
As you can see in this diagram.Orange, hot all the time.Goes to the lamp and red/black goes to the switch.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-13-2007, 04:16 PM   #3
STRNFAN93SL2
1997 SW2
Yup, I tried that but the lamp does not turn on.
Old 06-13-2007, 07:45 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
Its been a while since I installed an OEM latch in my 1995 SL2, but I believe the went from a negative switching system from the older cars to a positive switching system when they started using the electric latch. If I remember correctly.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 06-13-2007, 08:05 PM   #5
STRNFAN93SL2
1997 SW2
Hmmm...would I then need to get a relay to switch polarity from negative to positive?
Urgent: '01 SL2 door won't latch shut! pin S-Series Tech 4 12-06-2009 05:03 PM
'93 SC2 door latch assembly ab3n S-Series Tech 6 02-29-2008 01:32 PM
Rear driver door latch 97 SL2 mainedvd S-Series Tech 4 12-31-2007 05:17 AM
New trunk won't latch muzikmann S-Series Tech 4 12-14-2005 07:07 PM
'97 SL2 Armrest Latch SaturnGuy83 S-Series General 10 04-05-2004 02:09 PM
