Old 06-19-2020, 11:17 AM   #21
cityhawk
cityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to behold
cityhawk's Avatar
1993 SW2
Default Re: I went to check on a issue with my parking brake but found something way worse..
Nice job! That area will need some attention on my 1993 SW2, but I've slowed down the rot with some POR15. I'm working on the floors this year.
Saturns:
1993 SW2 MT 219,000 hard Boston city miles ("Rozzie")
Gone but not forgotten:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
1928 Ford Model A Tudor Sedan
Old 06-29-2020, 08:47 AM   #22
SLfun
2006 ION Red Line
Originally Posted by V3DT View Post
The passenger side has less rust.
No, I've already had enough fun with mine lol
Looks like mine. Now pop that plastic cover off the sill( there is one under every door) and fill that cavity with some rust proofing oil. I do mine 1x annually and the rust has stopped advancing.....been 5 years now.
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Old 08-30-2020, 11:55 AM   #23
Duner
Duner is on a distinguished road
1998 SL1
Looks like I might be in for same repair on my 98 SL1 in the future.
I was wondering how thick the metal should be for trailing control arm patch?
Any tips from people who have done this repair?
I was thinking in the range from 11 ga .120 th in. to 16 ga .060th inch.
Duner is offline   Reply With Quote
Old 09-04-2020, 09:21 AM   #24
V3DT
V3DT will become famous soon enoughV3DT will become famous soon enough
The metal I used was not that thick, I think 16 ga. I just went thinner because it was easier to work with & the metal in that area didn't seem to be that thick anyways. My thought was anything has to be stronger than what was left there. What was left of the mounting area was so soft I could just push on it with my fingers & feel it start to bend & since somehow the trailing arm had not broke off yet from driving around on the sucky roads around here, this should hold up fine.
You'd think the trailing arm would put quite a bit of force on that area but I'm guessing that force is mostly horizontal so the metal does not need to be very thick. I could be wrong, I'm not an engineer, don't take my word on it.
Though I went on a 1700 mile road trip with it last month & the patch held up fine.
V3DT is offline   Reply With Quote
Old 09-05-2020, 01:00 PM   #25
waiter21
2003 VUE 2.2L
WOW - And I thought that the Vue's were the only ones who suffered from this. I just repaired the rusted out front cradle mounts on my Vue, different approach, may not work for yours
http://www.1999southwind.com/toad-20...#ENGINE_CRADLE
Old 09-05-2020, 02:38 PM   #26
smoothz
smoothz is on a distinguished road
Oh my lord, how do you even react to that besides throw your tools -_-
smoothz is offline   Reply With Quote
Old 09-06-2020, 07:00 PM   #27
Duner
1998 SL1
V3DT, thank you much for reply. Very helpful.
Old 09-09-2020, 02:20 PM   #28
onlinebiker
I am literally on a first name basis with the guys at ALRO in Kalamazoo..... I buy all my steel, aluminum and stainless there.....
Currently owned
93 SC2
96 SC2
97 SL2
98 SL2
99 SC2
01 SC2 auto
01 SC2 5 sp
02 SC2
02 SL2 auto
02 SL2 5 sp
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 09-11-2020, 03:22 AM   #29
V3DT
Thought I'd give an update on some of the things I've done since then. Including replacing the oil pan because it rusted through, radiator because the plastic tank on the driver's side cracked, & just randomly wire brushing & painting areas of the frame. Trying to keep what is left of the car from turning into a fossil.
Old 09-16-2020, 07:12 AM   #30
00_SL1
00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough
00_SL1's Avatar
2001 SL2
What paint product are you using? Something like Rust-Oleum Rust Reformer, or POR-15?
01 SL2
04 Silverado
06 Uplander
05 Express
00_SL1 is offline   Reply With Quote
Old 01-29-2021, 06:54 AM   #31
V3DT
Whatever I could find cheap at places like Ollie's, walmart, ace, some Rust-Oleum Rust Reformer, Rust-Oleum black enamel, clear coat, some krylon primer + paint, some ace hardware branded spray paints.
Old 02-10-2021, 12:44 AM   #32
dakota1820
dakota1820 will become famous soon enoughdakota1820 will become famous soon enough
2000 SL1
My saturn has the exact same issue as yours.
Did you just tack in some nuts to the plate you installed and bolt the trailing arm up like that or?
dakota1820 is offline   Reply With Quote
Old 02-10-2021, 12:55 AM   #33
dakota1820
2000 SL1
Here is what mine looks like I took a screwdriver and poked around and this whole area was rotten.
Old 02-27-2021, 07:03 AM   #34
V3DT
More like engulfed the nuts in blobs.. Not pretty but I'm still sure it's stronger than what was left before.
Old 03-02-2021, 10:06 PM   #35
Duner
1998 SL1
Thought I was going to attach 2 pictures of my rust repair similar to what V3DT did.
http://www.saturnfans.com/forums/att...1&d=1614736058
Old 03-03-2021, 12:58 AM   #36
Excellent! Keep the pics coming. Maybe start a thread...
Old 03-09-2021, 10:00 PM   #37
cityhawk
cityhawk's Avatar
1993 SW2
Nice work!
Mine's not quite as bad in this area, but it's on my list. Next weld repair is to do my floors, which I didn't get to do last year. This will be a spring project. I did the door sills some time ago. Subframe is a bolt-on part.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 03-12-2021, 09:48 AM   #38
V3DT
Well pulled up the carpet & it was worse than I was thinking
Old 03-12-2021, 09:58 AM   #39
V3DT
Here is my progress into patching up that area so far
Old 03-12-2021, 10:01 AM   #40
Dude you are awesome!
How to check the parking brake switch? flyhop S-Series Tech 5 07-10-2017 08:14 AM
Parking Brake Issue trottida S-Series General 4 08-22-2016 12:56 PM
Parking brake issue? golftango Aura General 4 05-29-2010 01:24 AM
Parking brake/rear caliper issue derf S-Series Tech 17 04-02-2009 11:51 PM
'96 SC1 parking brake issue chadrules S-Series General 9 03-09-2009 09:06 PM
