Old 06-07-2001, 07:29 PM   #1
rogerk
rogerk is on a distinguished road
Default coolant, green phosphate free.
Where can I purchase green phosphate free coolant with out going to Saturn and paying 16 big bucks for a gallon of the stuff?
rogerk is offline
Old 06-07-2001, 08:06 PM   #2
91SL2
91SL2 is on a distinguished road
Default
I wrote to saturn regarding coolant,and this is the reply
"Thanks for writing Saturn! Saturn Corporation recommends you use
Non-Phosphate Ethylene (green in
color) to be mixed 50%(distilled water is best) water, 50% coolant. We
can not recommend or endorse
any other product.
For model years 1997-2001 Saturn recommends DEX-COOL (silicate-free)
coolant (red orange in color).
The water and coolant mix is the same as above.
If you need any additional information or assistance, please do not
hesitate to e-mail us again or
call us at 1-800-553-6000, option 3.
Thanks again,
Sheron Hobgood
Saturn Customer Assistance Center
qveh/acc
My car is an 91sl2 so i went with prestone,they do not say in the reply that it must be a saturn product.
hopes this helps
91SL2 is offline
Old 06-07-2001, 09:26 PM   #3
94sc2boy
94sc2boy is on a distinguished road
1994 SC2
Default
Don't believe that. I put the dexcool in my 94. I completely cleaned out the system first, then mixed it 50/50 with distilled water. I think you can get phosphate free at any parts store.
94sc2boy is offline
Old 06-07-2001, 11:13 PM   #4
Saturnmeister
Saturnmeister is on a distinguished road
Saturnmeister's Avatar
Default
The key on the "green" anti-freeze is it MUST be NON-PHOSPHATE...check the label of what you're buying. It must also be Ethylene-Glycol (you can't use the non-toxic propylene glycol). Regular Prestone is NOT non-phosphate, so careful! Their extended life anti-freeze is, I believe, though so that will work. You can use the "extended drain" anti-freeze (like Dex-Cool) in a car that had the green stuff originally, I believe - just don't go with the extended drain interval, since it's "contaminated" with the non-extended drain stuff already (nothing you can do 'bout that). Just check the label and confirm it is ethylene glycol first.
Saturnmeister is offline
Old 06-25-2001, 12:58 AM   #5
hamish
hamish is on a distinguished road
Default
You should ask some questions about the Dex-cool in the 94. I wanted to use it in a 92 and a 95 but was told by the dealer that the factory original hoses would be eaten through by the Dex-cool because they were not designed to use it. If ALL coolant carrying hoses had been replaced it would be OK, because the new replacement hoses would work with either anti-freeze. hamish
hamish is offline
Old 06-25-2001, 01:24 AM   #6
94sc2boy
1994 SC2
Default
I put the dex cool in my car in Novemeber I haven't seen a problem yet, I have noticed it running cooler, but thats it. If a hose goes I guess I'll just buy both and some heater lines. And add some more dexcool. thanks for the info hamish.
94sc2boy is offline
Old 06-25-2001, 06:45 PM   #7
Dr. Bob
Dr. Bob is on a distinguished road
Default
Re the DEXCOOL. The word I've heard is that DEXCOOL is ok, but the engine must be flushed thoroughly before changing from the ethylene glycol based antifreeze to the DEXCOOL. The different types of coolant and their chemical packages aren't compatible.
From what I've heard, the lifetime of DEXCOOL is extended only if the cooling system remains sealed. If it leaks and you have to replace coolant, the extended service life goes away quickly.
Dr. Bob is offline
Old 07-02-2001, 03:20 PM   #8
hamish
Default
If I recall correctly, there are more hoses than just the upper/lower rad and heater hoses that carry anti-freeze, so check the cooling routes before replacing. Possibly the problems I heard about came from a "mixture" rather than a flush and replace, I will see if I am able to find any more information. I am researching NPG+ from Evans Cooling as a replacement anti-freeze. The original NPG worked great in my late Volks GTI. hamish
hamish is offline
Coolant: Pink/Green/Distilled chad53916 S-Series Tech 19 07-20-2009 02:17 PM
HELP! My coolant went from Green to Brown! reemoe S-Series Tech 25 06-08-2005 05:41 PM
phosphate-free myth...!!?? Irba S-Series General 1 05-03-2005 10:46 AM
Looking for phosphate-free green coolant? Heartbeat - '95 SL2 Miscellaneous Tech 4 01-14-2003 08:31 PM
Coolant--phosphate/non-phosphate Case93sc2 S-Series Tech 2 06-23-2001 12:34 AM
