Old 03-18-2018, 04:06 PM   #21
Default Re: Flywheel Inspection Plate ? 2.2 non-Eco Tech.
Originally Posted by Chaz9496 View Post
.......My mechanic charged me $160 to tighten one bolt 2 years ago that was coming out and making a ticking noise. ......
What bolt loosened and required retightening?
Old 03-18-2018, 07:54 PM   #22
02 LW300
02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about02 LW300 has a spectacular aura about
02 LW300's Avatar
A loose torque converter bolt can tick as it backs out. If all three fall out you have lots of neutrals. LOL
2002 L200/5 loaded, loving my stick shift car finally on the road!
2002 L200 automatic, happy new owner
2002 LW300 sold.
Add to 02 LW300's Reputation
Old 04-15-2018, 10:26 PM   #23
Chaz9496
Chaz9496 is a jewel in the roughChaz9496 is a jewel in the roughChaz9496 is a jewel in the rough
2001 L-Series 2.2L Sedan
2003 L-Series 2.2L Sedan
Cracked flexplate. It took 2 weeks to do it but its back up and going again. The center was almost all cracked out. Lucky I stopped driving it when I did.
Add to Chaz9496's Reputation
Rate the quality of this post and help Chaz9496 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chaz9496 is offline   Reply With Quote
Old 04-16-2018, 09:56 PM   #24
That's really wild! This seems to be a rare failure, generally, although I'm sorry it happened to you.
I agree!
288,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 04-17-2018, 07:17 AM   #25
Dsaturn
Dsaturn is a jewel in the roughDsaturn is a jewel in the roughDsaturn is a jewel in the rough
Originally Posted by pierrot View Post
That's really wild! This seems to be a rare failure, generally, although I'm sorry it happened to you.I agree!
Very common if the bolts to the crank were not torqued properly and came loose.
Add to Dsaturn's Reputation
Old 04-18-2018, 12:57 AM   #26
In general, I see your point - but really......very common? The operative word in the quote above is the qualifier, "if." Out of every 10,000 cars produced by any given manufacturer, how many are likely to have this kind of problem present?
Old 04-18-2018, 06:48 AM   #27
Dsaturn
Out of the factory not so common but I have replaced a few of flex plates from back yard mechanics that either didn't tighten them enough or over torqued the bolts when doing engine replacement from manual to auto trans. I can not recall (Daewoo comes to mind) which Korean car manufacture it was back in the late 90s and early 2000s that had a recall because the flex plate bolts were not torqued properly.
Old 04-19-2018, 11:09 PM   #28
02 LW300
02 LW300's Avatar
We changed quite a few 77-78 Jeep Wagoneer flexplates and Chevy pickups and Suburban flexplates in the early 80s and they were all oem installs. Not many since. Lots of other problems but no flexplates.
2002 LW300 sold.
anybody have a flywheel inspection cover I can buy? Jesse Pinkman S-Series Tech 7 02-27-2016 01:03 PM
Flywheel inspection cover cityhawk S-Series Tech 7 01-20-2013 12:59 AM
inspection plate badbobby S-Series Tech 9 01-01-2012 12:36 AM
Flywheel Inspection 1991-1999 on manuals bgsneeze How-To Library 3 11-30-2005 07:35 PM
Dimensions of Flywheel, clutch, and pressure plate? ProDarwin S-Series Tech 1 12-06-2003 02:38 AM
