Old 02-15-2018, 07:01 PM   #1
IONic_2004
IONic_2004 has a spectacular aura aboutIONic_2004 has a spectacular aura aboutIONic_2004 has a spectacular aura about
IONic_2004's Avatar
2004 ION-2 Quad Coupe
Default 3rd gear has me down
My 3rd gear grinds forna split second during shifts. Its still easy to engage and stays in, am i looking at replacing/rebuilding the transmission? Or would something else cause it? 3rd gear is the only one so would that rule out clutch? Im still new to Saturns so advice from a seasond owner would be appreciated
2004 Saturn Ion 2.2 5speed
2006 Ford Focus ZX4 5 speed
1999 Oldsmobile Bravada 4.3 auto
1986 Pontiac Trans Am 5.0 auto
Add to IONic_2004's Reputation
Rate the quality of this post and help IONic_2004 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IONic_2004 is offline   Reply With Quote
Old 02-16-2018, 03:57 PM   #2
Default Re: 3rd gear has me down
Original owner or bought used? Mileage? Manual xmissions are usually bullet proof while the clutch, master and slave hydraulics wear out and gives symptoms of xmission problems.
Old 02-16-2018, 05:28 PM   #3
IONic_2004
IONic_2004's Avatar
Bought used a week ago. Has like 207k how had is the slave cylinder to replace?
Old 02-16-2018, 06:02 PM   #4
At 207k miles, this car is well used. Maybe replacing the xmission fluid (Dexron III) will help before considering a worn clutch or hydraulics. The clutch slave unit comes off when the xmission is separated from the engine. I don't know if Ion manuals wear out the same way as any other car but its usually recommended to replace clutch and hydraulics all at the same time with high mileage and not piece meal since replacing a slave means bleeding the system and repeating it again if the master is replaced at a later time. When considering replacing a clutch, once the xmission is separated, replacing hydraulics makes sense instead of revisiting this point later when hydraulics fail after replacing a clutch.
Old 02-17-2018, 04:49 AM   #5
IONic_2004
IONic_2004's Avatar
I will give those a read tonight but just quick skiming i see the word "clash" is that the same thing as grinding?
Old 02-23-2018, 06:06 PM   #6
IONic_2004
IONic_2004's Avatar
well the car passed the static and dynamic shift tests. ill try the fluid change and go from there
Old 03-11-2018, 07:17 PM   #7
IONic_2004
IONic_2004's Avatar
ok to update everyone: i drained the old fluid (was kinda brown) and replaced with 1.5 qts of Castrol Transmax Dex/Merc and half qt of Lucus transmission additive to thicken it up
3rd gear still grinds going in but at lower speeds (2000 RPMs) she engages nice and quiet. am i gonna be looking at a trans rebuild/replace in the future?
Old 03-12-2018, 11:53 AM   #8
bluesl2
bluesl2's Avatar
Probably the blocker ring for third gear is shot. I would try looking for a used transaxle but the manuals may be hard to come by. Parts are probably still available to rebuild if you go that route.
Add to bluesl2's Reputation
S Series MP3 5th gear swap to lower MP2 gear? Dman12ny S-Series Tech 4 07-11-2017 09:09 AM
2000 SL2 Car won't shift into any gear, stuck in 1st gear? MyCarBroke S-Series General 3 11-26-2016 01:36 PM
5th gear swap, gear stack mess... mattwithcats S-Series General 2 04-23-2015 07:54 PM
P0731 P0734 Incorrect Gear Ratio - Trans Locked in 2nd Gear NoColoradoGT S-Series Tech 18 04-03-2014 03:55 PM
auto 95sw2 2nd gear doesnt fully engage until right before 3rd gear shift? kaptnjack S-Series Tech 4 01-06-2010 08:10 PM
