Old 04-08-2012, 12:51 AM   #1
jclever83
jclever83 is on a distinguished road
Default Thermostat Change now big problem
2003 Saturn Vue 3.0 I live in California and its been around 65-75 the last 2 weeks. Sorry, this is going to be long but I want to give as much info as possible. After thermostat change I have overheating issues.
With that said, I just changed out my water-pump (because of a leak), timing and serp belts, thermostat, plugs, and valve covers (slight oil leak). Before the repairs I didn't have a overheating issue but I did have the P0128 code. Though a pain in the ass everything went as it should. I put everything back together, added about 3/4 quarts of Dexcool 50/50 to the reservoir tank and started it right up. Sounded great. Let it idle in the driveway for 20-30. As I was cleaning up I kept my eye on the coolant tank and temp gauge. The tank only lost about 1" of fluid in that time. At the end of the 30 mins I checked the temp gauge and it was in the RED!
I immediately turned the car off. There were no leaks under the car, anywhere on the block, and I looked down where the thermostat housing is and there WAS NO puddle in there. After a visual inspection I unscrewed the oil cap and there was white milkiness on the cap and on the throat of the fill tube (there has never been and milky goo there before). Also, when the car was shut off you could here a gurgling/bubbling sound coming from inside the engine).
What happened??? I dont want to tear into the car again yet until and I get a little feedback. Please help I cant afford to take this to a stealership. Happy Easter and Thanks.
Add to jclever83's Reputation
Rate the quality of this post and help jclever83 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jclever83 is offline   Reply With Quote
Old 04-08-2012, 08:39 AM   #2
Chazberry
Chazberry's Avatar
Default Re: Thermostat Change now big problem
Happy Easter to you! Sorry it isn't happier, but it sounds like you just have some air in the system. Maybe try loosening the top radiator house.
See this post re: milky stuff in the oil fill . . .
http://www.saturnfans.com/forums/sho...9&postcount=29
Add to Chazberry's Reputation
Old 04-08-2012, 09:04 AM   #3
Saturns take almost 2-gallons of coolant. With only 3/4 of a gallon used, was the cooling system already filled or only half filled?
Old 04-08-2012, 10:38 AM   #4
jclever83
Thanks for the replies. It sucks going to bed and all you can think about is how bad you f'd your car up. I even dreamed about it. I got to watch my daughter hunt for her Easter basket so its still pretty happy.
When I drained out the coolant for the different tasks (waterpump, disconnecting radiator hose) I think I lost about a gallon of coolant. I put one gallon in and planned on adding more when the engine sucked the reservoir dry.
I'll try bleeding the system by a method I read on another post. (cast repost it because I'm a newbie) Basically involved running the engine till the fan comes on and have the cabin heater on high, shutting off, refilling, repeat. I'll loosen the top rad hose also to let the air escape.
Any other tips?
BTW, you cam locks worked awesome Chaz.
Old 04-08-2012, 11:16 AM   #5
Chazberry
Chazberry's Avatar
Any other tips?
Glad to hear it. Good luck with the bleeding operation. I wouldn't think running the Cabin Fan would have any effect - maybe cycling the Temp Control (?). I can't think of anything else to try.
Old 04-08-2012, 02:19 PM   #6
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
The first time I did a drain and refill of coolant, my temp gauge went up all the way too. Months later, I found out that my "low speed cooling fan resistor" was broken, and could have contributed to the over heat. I replaced it, and when I did the coolant change again later, there was no overheating. A good way to test the "low speed cooling fan resistor" is to turn on the air conditioner, and the cooling fan on the radiator should come on in less than a minute.
It's GOOD to have a spare!
Add to termite's Reputation
Rate the quality of this post and help termite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
termite is offline   Reply With Quote
Old 04-08-2012, 04:50 PM   #7
Heater core is likely air blocked.
If you have access to a coolant vacuum filler then that is the best way to refill the VUE cooling system. Engine revving may get the coolant flowing through the heater core. If that does not work then cracking the heater hoses open to let the air out (likely a few times) should get the coolant going.
Add to ssicarman's Reputation
Old 04-08-2012, 08:39 PM   #8
Originally Posted by ssicarman View Post
Heater core is likely air blocked..... cracking the heater hoses open to let the air out (likely a few times) should get the coolant going.
Engine with gastrointestinal problems?
Old 04-08-2012, 09:57 PM   #9
I think that would be in the exhaust???
This might in the vascular system.
Unfortunetly the heater core is is lower than heater hoses coming up from the core and they are shaped so that liquid flow is had to get going again when there is air in the hoses.
Old 04-08-2012, 10:01 PM   #10
You're right! Its a good thing I didn't become a surgeon......................
Old 04-09-2012, 10:55 PM   #11
jclever83
Everything is good! I let is yesterday morning I popped the hood and most of the coolant had drained from the reservoir. Filled it back up to the Max line and let it idle for a little bit then bleed it every few minutes. Took it for a freeway test drive to get it hot and the temp gauge never rose above a little past 1/4. Thanks Guys!
2002 vue 3.0 thermostat change dzabo Vue Tech 31 01-20-2014 07:48 PM
Thermostat change 2006 Vue V-6 IndianaDave Vue Tech 2 12-15-2010 12:03 PM
About thermostat change xybaby S-Series Tech 10 07-08-2009 01:39 PM
bad luck after thermostat change kaptnjack S-Series Tech 20 02-15-2009 10:58 PM
Thermostat change bobsart S-Series General 12 03-17-2006 11:46 AM
