Old 02-12-2017, 05:50 PM   #1
truck1985
truck1985 is a jewel in the roughtruck1985 is a jewel in the roughtruck1985 is a jewel in the rough
2004 ION-3 Sedan
Dizzy Clutch won't disengage
I have a 2004 Ion level 3. I've had issues with the clutch recently. It was feeling very spongy and not disengaging fully. I tried bleeding the system, but that didn't help. I replaced the master cylinder and tried bleeding the system again, to no avail. I had the clutch kit, including the slave cylinder, and flywheel replaced. The shop that did the work had to use their air compressor to push air into the system to manage to bleed the slave cylinder. This fixed it, for about a day. Now it won't disengage again. I bought a pressurized brake/clutch bleeder. After getting the system under pressure, I pumped the clutch continuously for over half an hour. That seemed to work, until I let the car sit without pressure on the hydraulic system for a few hours. Now it won't disengage at all again. What would you guys recommend I look at next? Should I replace the lines running from the reservoir to the master cylinder and from the master cylinder to the slave cylinder? What is the part that is between the master cylinder and the line going to the slave cylinder? What are the part numbers for these parts?
Truck1985
2004 Saturn Ion3 Manual
1992 Saturn SC Auto
No mods
Add to truck1985's Reputation
Rate the quality of this post and help truck1985 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
truck1985 is offline   Reply With Quote
Old 03-09-2018, 10:32 PM   #2
pancholin
pancholin is on a distinguished road
Default Re: Clutch won't disengage
It's funny, I have been looking for clutch pedal threads and most if not all go unanswered.
Add to pancholin's Reputation
Rate the quality of this post and help pancholin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pancholin is offline   Reply With Quote
clutch will not disengage tattoojoe1526 S-Series General 6 12-14-2014 10:16 AM
Clutch won't disengage after clutch swap insta S-Series General 8 04-29-2009 08:20 AM
'96 SL1 A/C Clutch won't disengage Saturndaddy S-Series Tech 3 06-26-2008 10:48 AM
Clutch replaced - cannot disengage chadrules S-Series Tech 7 03-05-2007 09:00 PM
WTF!!! Clutch won't disengage miken68 S-Series Tech 5 10-17-2006 09:37 AM
