Old 12-21-2016, 12:49 PM   #1
Rvcrazy
Rvcrazy is on a distinguished road
Default Check engine on P0700 and P0705 codes?
Car starts and runs beautiful despite check engine light on. Some days the car drives and shifts perfect through all the gears. Another day i can go from reverse to drive and it doesn't move without a bit more gas than normal, once going it's fine but doesn't come out of first, seems just like it works in 2nd and 3rd.....it will get me from point A to point B ....I scanned it at a tranny shop, codes found P0700 and secondary code P0705....Range code/selector and neutral safety switch?????/ what gives here....shop was out of town, they were to busy to get into it what it really needed to be right again
Add to Rvcrazy's Reputation
Rate the quality of this post and help Rvcrazy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rvcrazy is offline   Reply With Quote
Old 12-21-2016, 02:30 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: Check engine on P0700 and P0705 codes?
Year? Quad Coupe or Sedan?
Which transmission?
Mileage?
Sounds like a bad park/neutral/range switch. In other words the computer can't tell what position the shifter is in.
2007 Ion 2 Quad Coupe 5-speed manual 179K miles
2007 Chevy Equinox LT 190K miles
Add to ruley73's Reputation
Old 01-31-2018, 10:29 PM   #3
j.small17
j.small17 has a spectacular aura aboutj.small17 has a spectacular aura aboutj.small17 has a spectacular aura about
2009 Astra XE
Having a similar issue on my 09 Astra auto transmission.
Issue has been intermittent (started during a 2-week period of -30C to -40C degree weather. Once weather warmed up, the issue went away. Has recently returned). Here is what's happening:
- On first drive of the day, the car runs fine, with no symptoms (other than check engine light)
- On the next drive, once I move the shifter out of P, all of the indicator lights on the shifter come on and "--" appears on dash where the transmission position would normally appear.
- Car is super sluggish when accelerating out of a start (feels like it's trying to get going from 3rd?)
- I can shift myself, though it is SUPER rough going from 1-2
- Super rough shifting into R too
- Cruise control does not work at all when these symptoms are active (works fine on 1st drive of day)
- P0705 code (and one more. Can't recall atm)
Had the same codes on an 01 Focus and replaced the range sensor. Is the Neutral Safety Switch the Saturn equivalent to range sensors? Are there any reliable aftermarket range sensors/Neutral Safety Switches that anyone has used and can recommend? I'm seeing the GM part for $350 +tx and don't want to drop that much on the part if I don't have to.
Add to j.small17's Reputation
Rate the quality of this post and help j.small17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
j.small17 is offline   Reply With Quote
2003 ion m43 trans p0705 p0700 code qwertio12 Ion General 3 04-11-2015 03:18 PM
Can you pull engine codes with an OBD if the check engine light is OFF? jedisaturn S-Series General 2 04-07-2015 11:15 PM
Check engine codes... I need help!!! Bflener L-Series Tech 79 03-29-2013 07:49 PM
Codes P0700, P1758 cutiep Vue Tech 3 05-05-2009 01:58 AM
P0700 P0442 SES Codes madgor Vue Tech 1 03-23-2009 06:05 AM
