Old 11-10-2010, 05:56 PM   #1
mike97478
mike97478 is on a distinguished road
Default 2007 vue turn signal switch replacement
My turn signal will not turn off after making a left turn - right turn is ok.
Has anyone changed the turn signal switch / module on a 06 / 07 vue? The dealer wants $200.00 or so to replace it and said the part is around $55.00.
Any help would be greatly appreciated.
Thank you in advance.
Mike97478
Add to mike97478's Reputation
Rate the quality of this post and help mike97478 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mike97478 is offline   Reply With Quote
Old 06-08-2012, 11:21 AM   #2
mikenews
mikenews is on a distinguished road
Default Re: 2007 vue turn signal switch replacement
Having the same problem... mine the lights actually dim on the dash and radio when turning left. I am going to replace it. Doesn't look to hard.
Add to mikenews's Reputation
Rate the quality of this post and help mikenews reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikenews is offline   Reply With Quote
Old 06-08-2012, 07:50 PM   #3
TheVue
TheVue is on a distinguished road
TheVue's Avatar
I've replaced the turn signal switch my 07. Very easy repair, maybe 20 minutes. About $38.00 plus shipping from Rockauto.com
Add to TheVue's Reputation
Rate the quality of this post and help TheVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheVue is offline   Reply With Quote
Old 06-08-2012, 08:53 PM   #4
far2grumpy
far2grumpy's Avatar
I agree - you can hook a finger in the top cover (next to turn signal/light lever) and give a sharp upward tug to pop the cover off.
The bottom cover can be dropped by removing the three 5.5 mm screws but try with just the top cover first.
Make sure you order the correct switch - there's one for AUTO headlamps and one without. They're not interchangeable.
Old 09-22-2017, 10:53 AM   #5
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
The left turn reset also stopped working on my VUE. Took all of 2 mins to replace the switch. I appreciate the great job the engineer did making this so easy to replace.
I ordered an original Delco replacement from amazon. There was several generic knockoff's available for half the price. The original lasted 11 years, I do not want to waste time and money on a generic copy.
To replace...
1. Grip and unsnap the top cover over the switch.
2. Remove the wiring harness from the turn signal switch.
3. Then squeeze the release levers on the top and bottom of the old switch.
While squeezing the levers, push the switch assy in and out while pulling it outward. It will then slide out. My switch was really tight.
4. Slide in the new switch until it snaps in place. You'll see there's square guide rails on the top and bottom of the switch. Line them up and slide it in place.
5. Plug back in the wiring harness.
6. Snap back the top cover over the switch.
Add to BobbyP's Reputation
Turn signal problems (not caused by bad flasher / hazard switch??) MRink Vue Tech 12 07-05-2016 06:57 PM
1995 Saturn SL2, procedure to replace combination turn signal / wiper switch David598 S-Series General 8 01-08-2010 07:46 PM
Turn signal switch problem blupupher Vue General 12 08-11-2009 07:58 AM
Turn signal switch replacement gehrhardt S-Series Tech 2 12-15-2008 03:23 PM
LW Turn Signal Stalk Replacement IceMan2 L-Series Tech 1 11-11-2007 12:28 AM
