Old 12-15-2008, 01:20 PM   #1
gehrhardt
gehrhardt is on a distinguished road
2006 ION-3 Sedan
Default Turn signal switch replacement
I have a 98 SL2 that decided it would start self-destructing on me on a road trip this weekend. The muffler detached itself from the exhaust pipe 450km from home, but that was the least of my problems.
Also a long distance from home, I could smell a burning electrical smell. We got to our hotel and when we returned to the car, I could see smoke rising from the steering column. I noticed that the blue high beam indicator would light up without the high beams being turned on as well.
I had posted on this site a while back about the car blowing signal light fuses frequently. It turns out I ran out of 10A fuses and put a 15A one in there as a temporary thing until I got some more. I forgot about it (stupid me) and now I assume the wires shorted and caused the smoke. I have since pulled the fuse and of course, the problem went away (along with my signal lights).
It was not a pleasant drive home for 5 hours with no turn signals or muffler.
Has anyone ever tried to replace the turn signal stalk on a 2nd Gen S-series? I assume I will need to remove the steering wheel to get at the column.
Any help would be appreciated.
Add to gehrhardt's Reputation
Rate the quality of this post and help gehrhardt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gehrhardt is offline   Reply With Quote
Old 12-15-2008, 02:04 PM   #2
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Default Re: Turn signal switch replacement
Never, ever ASSume. Find out what the problem is, then find out how to fix it, not the other way around. And yes, if the turn signal switch does check out bad, the steering wheel will have to be removed to replace it, which is the hardest part of the job.
Certified Saturn Technician
Old 12-15-2008, 03:23 PM   #3
Originally Posted by Squareback View Post
And yes, if the turn signal switch does check out bad, the steering wheel will have to be removed to replace it, which is the second hardest part of the job.
Fixed. Your generation of wheel will come off with just about any generic steering wheel puller. The honestly trickier thing will be removing the column covers. That requires either a 5.5mm (or suitable fractional equivalent) nut driver, or a 5.5mm (or equiv) socket with its outer wall shaved down to fit in the holes.
Oh, and it's not just the stalk. All the switches on the column (except the ignition switch) are on one assembly -- the Lever Combination Switch. Same amount of work, fortunately. Dealer part will cost you more than an Illinois political bribe; try http://www.car-part.com for a salvage part (or check our Classifieds). This is assuming, of course, that the switch is the cause of the issue, and not an effect of some issue elsewhere.
Don't forget to disable the air bags before you remove the wheel. Pull the AIR BAG fuse and wait 30 minutes for the capacitor to discharge.
Add to madpogue's Reputation
1995 Saturn SL2, procedure to replace combination turn signal / wiper switch David598 S-Series General 8 01-08-2010 07:46 PM
Turn signal switch problem blupupher Vue General 12 08-11-2009 07:58 AM
turn signal indicator bulb replacement ebshumidors S-Series Tech 2 10-05-2008 06:40 PM
LW Turn Signal Stalk Replacement IceMan2 L-Series Tech 1 11-11-2007 12:28 AM
Turn signal out? preduck Ion General 26 07-20-2003 02:28 PM
