Old 06-30-2020, 06:46 PM   #1
Tbrandon1992
Tbrandon1992 is on a distinguished road
2001 L-Series 3.0L Sedan
Default 2001 l300 sedan spark plugs
So i know how to get to my 2 4 6 plugs (which yes i discovered 2 of the wells full of oil so next step for front is valve cover gasket!) the back is intimidating me a little tho with all the **** there....any tips on getting to the coil pack/plugs to see if they are covered with oil also?
Tbrandon1992 is offline   Reply With Quote
Old 06-30-2020, 07:01 PM   #2
Rj 2000 LS2
2000 L-Series 3.0L Sedan
Default Re: 2001 l300 sedan spark plugs
It is intimidating because its a pain in the rss! Getting at the QPaks is not nearly as painful as getting to the valve covers which requires you remove front and back motor lift mounts. There is no room to get a wrench on the bolts and less room to see what you are doing. Then there is the EGR valve removal... You are right the front plugs are easy. Stay intimidated on the rear plugs and the valve cover gaskets because they are all of that and then some!
Rj 2000 LS2 is online now   Reply With Quote
Old 06-30-2020, 07:56 PM   #3
Tbrandon1992
Well cant say that's what I wanted to hear but kind of what I assumed. I've decided this will be my project car to attempt most fixes on. I've always had a decent amount of knowledge but have never really put it to practice.So have you ever done it before? I'm just crossing my fingers that the wells wont be full of oil back there.
Old 07-01-2020, 12:19 AM   #4
Rj 2000 LS2
I have done it 4 times and now I could do it in my sleep. Read my I blew it up summary where I describe the entire process and all the headaches along the way.
Old 07-01-2020, 03:21 AM   #5
Dsaturn
2001 L-Series 2.2L Sedan
When you do the motor mounts do not use a breaker bar to tighten them.
https://www.infowars.com/ The answer to 1984 is 1776. We are not a Democracy. We are a Constitutional Republic. A Democracy is Two Wolfs and a sheep deciding what is for Lunch!
Old 07-01-2020, 06:32 AM   #6
Tbrandon1992
Can you post the link to the thread? Can't seem to find in a search.
Old 07-01-2020, 07:22 AM   #7
BrandonKastning
BrandonKastning will become famous soon enough
BrandonKastning's Avatar
Roll Eyes Re: 2001 l300 sedan spark plugs
What Dsaturn said ^
I know for certain
Old 07-01-2020, 12:54 PM   #8
Rj 2000 LS2
And you said to yourself, Self, why am I here?
Old 07-01-2020, 02:55 PM   #9
Tbrandon1992, some hints related to this thread are listed on the bottom of the page under Similar Threads.
Old 07-01-2020, 03:09 PM   #10
BrandonKastning
Thumbs Up Re: 2001 l300 sedan spark plugs
Tbrandon,
If you get yourself a good pry bar; you can easily remove the rear intake ("engine stuff"); just label it and push it aside. You do not have to remove the upper intake to get to those rear plugs.
You can take the pry bar and pry the rear intake manifold to "flip" backwards... allowing full access to the Coil Packs and Spark Plugs.
I wouldn't be too concerned; just label and don't break anything. You will need specialized tools (E8 + E10) sockets and a Spark Plug T Wrench (However you probably know that). And a flat head screw driver and you should be set!
Best Regards,
Brandon
Old 07-01-2020, 05:35 PM   #11
Rj 2000 LS2
Oh, Boy. What we have here is a case of multiple Identities! Enjoy!
Changing Spark Plugs on L300 3.0 V6 hufhouse L-Series Tech 18 07-13-2015 08:34 PM
Spark Plugs & Thermostat L300 Partymmudasti L-Series Tech 5 12-10-2013 06:52 PM
'03 L300 3.0L V6 spark plugs mcmotorhed L-Series Tech 1 01-19-2010 04:24 PM
'01 L300 Spark Plugs Hakman L-Series Tech 5 01-19-2010 03:40 PM
2001 L300 Changing Spark Plugs Wanabflyin L-Series General 4 01-21-2005 11:30 AM
