Old 11-14-2014, 12:10 AM   #41
REALFUNCO
REALFUNCO is on a distinguished road
Default Re: Valve Body Replacement
I have a 2001 SC2. The trans is not operating correctly. It starts out in high gear 3rd or 4th. The diagnostic codes are PO732, 733. Reverse works good.
I've been reading about the issues, testing, troubleshooting and so forth.
I took off the elec connector(it looks great, no burnt connections) on the valve body and tested the ohms. a-b=5 ohms c-d=6.8 ohms e-k=6.8 ohms g-f=5 ohms h-j=7.1 ohms
Different sites give different specs for checking the ohms on the solenoids. If 7.1 ohms is an acceptable reading, then there is another problem.
The service engine light is on.
Last edited by REALFUNCO; 11-14-2014 at 12:19 AM. Reason: new guy who is unfamiliar to the site
REALFUNCO is offline   Reply With Quote
Old 11-14-2014, 10:38 AM   #42
Chazberry
Chazberry's Avatar
1995 SW2
Have you checked your TRS fuses?
http://www.saturnfans.com/forums/att...0&d=1351120664
I took off the elec connector (it looks great, no burnt connections) on the valve body and tested the ohms. a-b=5 ohms c-d=6.8 ohms e-k=6.8 ohms g-f=5 ohms h-j=7.1 ohms
Some of those readings are high - should all be around 5 Ohms . . .
http://www.saturnfans.com/forums/att...5&d=1324008344
Old 12-11-2014, 07:19 PM   #43
tooter1
tooter1 is on a distinguished road
Nice write up. I was doing this earlier.
'03 Saturn ION Level 3 Sedan
'01 Saturn SL2
'00 Saturn LS2
tooter1 is offline   Reply With Quote
Valve Body Replacement andy_95sl2 S-Series Tech 18 11-03-2014 04:50 PM
valve body replacement bdobraj S-Series General 57 05-04-2009 09:42 PM
Valve Body Replacement? cslade S-Series Tech 1 09-12-2007 10:48 PM
Valve Body Replacement Mike1969 S-Series Tech 5 08-30-2006 10:39 PM
Valve body replacement nick95sl2 S-Series General 0 09-28-2005 08:22 AM
