Old 08-18-2009, 10:43 AM   #21
westside27375
westside27375 is on a distinguished road
2002 VUE 3.0L
1993 SL1
Thumbs Up Re: A/C will only work on low fan speed
Originally Posted by fdryer View Post
For your '03 Vue, its behind the blower motor.
Thank you
westside27375 is offline   Reply With Quote
Old 08-18-2009, 11:14 AM   #22
far2grumpy
far2grumpy's Avatar
Default Re: A/C will only work on low fan speed
If you can't find the resistor board on rockauto website call them at 1-866-762-5288. Phone lines are open daily for several hours.
Old 08-19-2009, 10:19 AM   #23
plum_sc2
plum_sc2 is on a distinguished road
1993 SC2
Default Re: A/C will only work on low fan speed, update
Originally Posted by 1469929
OK, here's something I hoped for but did not expect...
I got a replacement resistor board in the mail today. Put it it in and both problems are gone. Fan speed #1 works and the a/c now works on all fan speeds. The a/c compressor no longer cycles..I watched it for 10mins straitgh and I did not do that cycling thing from before. It blows cold air quickly and I'm quite happy because It's going to be hot the next 10 days.
Just for kicks I put the old resistor board back in and the same old problems come back...so there's a definite relation.
I still want to do a pressure test just in case and maybe fill the a/c coolant up..
Is it worth it? Does a 7 year old Vue need to get a/c coolant added?
Thanks.
OK, I have the exact same issue with my 03 Vue......... Where's this resistor board located? I see FDRYER said "behind the blower motor" ........ is that under the hood or under the I/P somewhere?
1993 SC2 - 168,000 miles
2003 Vue - 104,000 miles
plum_sc2 is offline   Reply With Quote
Old 08-19-2009, 10:26 AM   #24
far2grumpy
far2grumpy's Avatar
Inside vehicle cabin - right side - above passengers feet - below and behind glove-box.
There's a close-out panel to be removed.
Old 08-19-2009, 10:29 AM   #25
plum_sc2
1993 SC2
Thanks Grumpy............. whats the time frame on replacing this board? 30 min? 2 hours?
Old 08-19-2009, 10:58 AM   #26
far2grumpy
far2grumpy's Avatar
I've not changed one of these things but with my age and bad-back it'd take a large dent in a six-pack (including pre- and post-task contemplation).
Someone younger, more fit and less inclined to forget why they were upside down in the front passenger foot-well ... 30 minutes at most.
Old 08-19-2009, 11:01 AM   #27
plum_sc2
1993 SC2
LOL !! I like your timing "unit of measure" ......
"Yea that'll be a 4 beer job"
Old 08-19-2009, 11:26 AM   #28
bestharry
bestharry is on a distinguished road
bestharry's Avatar
2003 VUE 2.2L
Happy Re: A/C will only work on low fan speed
5-10 minutes......if you have the right tool.....
Harry in Toronto with:
2003 Saturn Vue 2.2 Manual - (Not so) Recent edition
1997 Volvo 850 wagon - Love this Black box (sold)
bestharry is offline   Reply With Quote
Old 05-31-2011, 02:49 PM   #29
risknotdonot
risknotdonot is on a distinguished road
The blower resistor card swap fixed my issue. Same issues as the original poster. You will need either an 8mm or a 5/16 wrench and i used flip flops for my knees. The back bolt is a pain but if you use a 1/4 drive ratchet it is good. the plastic bump in the way moves back easily enough. It took about 10 minutes of total time working it out. Part was 80 dollars at the dealer in Va Bch,Va. Would never have thought of this without the help of everyone in this forum.
risknotdonot is offline   Reply With Quote
Old 06-18-2011, 08:31 AM   #30
merlin5353
merlin5353 is on a distinguished road
I'm a bit less flexible. It took me almost 15 minutes of cussing. The 'bump' was a pain (also my knees). I'm surprised it was out in 'plain sight' like that. NOT like my spark plugs.
Thanks to all!
merlin5353 is offline   Reply With Quote
Old 07-01-2020, 08:10 PM   #31
snowiboywi
snowiboywi is on a distinguished road
I have 2006 Saturn Vue with the V6.
The fan was blowing at all settings (low to high) but the AC light was only lighting up when on 1 (lowest) or 2(low). Once I turned fan to 3 or higher, the blower continued to work and blow higher, but the orange AC light went off and no condenser engaging.
I replaced the blower motor resister as explained above and it fixed my issue!
Thank you so much for these posts and forums.
Tom
snowiboywi is offline   Reply With Quote
a/c, fan, hvac
Cooling fan won't work, tried everything! clutch1983 S-Series Tech 4 04-07-2009 09:19 PM
cooling fan low speed resistor ohm value? t34rus Vue General 13 03-10-2009 11:18 PM
Where is the low speed cooling fan resistor? 03Vue Vue Tech 8 05-12-2008 09:00 PM
98 fan does not work billison S-Series General 21 08-02-2006 03:17 PM
fan does not work billison L-Series General 2 07-29-2006 10:25 AM
