Old 11-14-2018, 07:34 PM   #1
SlayZombi
SlayZombi will become famous soon enough
2001 SL
Default Valve Cover Painting
Just thought I would share a pic of a painted valve cover I did today! It's a little rough around the lettering but I'll be clearing that up once everything cures.
Add to SlayZombi's Reputation
Rate the quality of this post and help SlayZombi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlayZombi is offline   Reply With Quote
Old 11-14-2018, 08:09 PM   #2
hholbein
1997 SW2
Default Re: Valve Cover Painting
Wow! SOHC Pride!!!
Add to hholbein's Reputation
Old 11-14-2018, 08:45 PM   #3
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
Nice job! Did you strip all the existing paint down? Getting in the nooks and crannies of those raised letters is a helluva hard job.
Looks really nice!
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Rate the quality of this post and help dummo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-14-2018, 09:03 PM   #4
Macgyver
I typically powder coat the valve covers on the engines I rebuild, I just leave it the OEM color though. The trick is to paint the entire thing and then sand the top of the letters. You could then go over the bare metal with the color of your choice if needed.
Add to Macgyver's Reputation
Rate the quality of this post and help Macgyver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-14-2018, 09:37 PM   #5
Bearded1mx3
Bearded1mx3 will become famous soon enough
Here's another trick for the raised letters. I just covered mine with vaseline prior to paint then after u paint just a qtip and rubbing alcohol. Wipes right off.. And to prep I simply put it in my bathtub and washed it with a green scrubber sponge and dish soap lol...ahhhhhh apartment living
Old 11-15-2018, 01:50 AM   #6
SlayZombi
2001 SL
Looks really nice!
No I just cleaned it off really good and then sandpapered the existing paint to let the primer "grab" onto something. Then I used a can of black VHT engine enamel to get the clean gloss black look. Letters were actually done BEFORE the black by spraying it red and letting it sit overnight, then I put silicon grease over the letters so the black wouldn't stick. After all was said and done I simply peeled back the black paint off the grease to expose the red lettering! Clearly I need to peel off the small tidbits here and there though.
Old 11-15-2018, 02:41 AM   #7
Bearded1mx3
You my friend are a genius
Old 11-15-2018, 11:37 AM   #8
SlayZombi
2001 SL
Thanks! Old friend of mine showed me that little trick.
Old 11-15-2018, 01:57 PM   #9
ratwhisperer
ratwhisperer is a jewel in the roughratwhisperer is a jewel in the roughratwhisperer is a jewel in the rough
ratwhisperer's Avatar
1997 SL1
Ooh that's purty!
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
1994 SL2 - Nelly Belle
Current:
1997 SL1 - Cinnamon - 285K
1996 SL2 - Blanca - 36K
Add to ratwhisperer's Reputation
Rate the quality of this post and help ratwhisperer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ratwhisperer is offline   Reply With Quote
Old 11-19-2018, 02:59 PM   #10
Saturn Night
Very nice job.
Painting your valve cover?? RZRIvan Relay General 0 04-03-2007 01:14 AM
painting cam cover? agoldslsaturn S-Series Mods 12 04-08-2006 10:45 PM
Painting Valve/Cam Cover getz999 Mods and Performance 11 07-11-2005 10:06 AM
Painting the Cam Cover hummers86 Miscellaneous Tech 1 03-23-2004 01:09 PM
Painting valve cover, Help?!? MeaNGreeNSL2 S-Series General 4 03-06-2004 12:20 AM
