Old 08-05-2010, 08:23 PM   #1
knclark67
knclark67 is on a distinguished road
Default Timing belt and associated damage?
If the timing belt snapped, how much damage can this cause to the engine?
Add to knclark67's Reputation
Rate the quality of this post and help knclark67 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
knclark67 is offline   Reply With Quote
Old 08-05-2010, 08:31 PM   #2
mrtube
mrtube is on a distinguished road
Default Re: Timing belt and associated damage?
very few engines are not damaged atall by design.
Most engines can sustain enough damage that they will need a complete rebuild or a top end rebuild at a minimum.
point being, don't let it happen you won't be happy.
Add to mrtube's Reputation
Rate the quality of this post and help mrtube reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrtube is offline   Reply With Quote
Old 08-06-2010, 01:41 PM   #3
VTchemist
VTchemist is a jewel in the roughVTchemist is a jewel in the roughVTchemist is a jewel in the roughVTchemist is a jewel in the rough
VTchemist's Avatar
What engine? I think the L81 (GM-OPEL) V6s used in the 02 and 03 are "interference" engines. A broken belt would result in the valves and pistons crashing together.
Perhaps the Honda and GM posters will add to this post.
Add to VTchemist's Reputation
Rate the quality of this post and help VTchemist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VTchemist is offline   Reply With Quote
Old 08-06-2010, 02:28 PM   #4
knclark67
I have a 2003 V6 on a Saturn Vue.
Old 08-06-2010, 09:57 PM   #5
ssicarman
ssicarman's Avatar
Minimum will be bent valves.
Add to ssicarman's Reputation
Old 08-06-2010, 10:55 PM   #6
Venomized
Venomized is on a distinguished road
Venomized's Avatar
Many years ago I had a 73 Nova that the timing chain slipped teeth on from old age. I got lucky and only bent push rods. I don't want to take that chance ever again.
06 Vue AWD V6
01 Grand Cherokee
05 Gulfstream Conquest 28 foot class C
Add to Venomized's Reputation
Rate the quality of this post and help Venomized reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Venomized is offline   Reply With Quote
Old 04-11-2011, 08:28 AM   #7
cw2899
cw2899 is on a distinguished road
I have a 2003 VUE V6 and just replaced the timing belt. As luck would have it the AC compressor siezed up and as a result caused the serpentime belt to lock and the timing belt to shear apart (or so the shop says). Now I am looking at $3500 in repairs as I have a bent valve, need a new AC compressor, the hear has to be sent out to be machined for the new valve and ann the other parts that have to be replaced. I really question how this is possible since the AC compressor should cause the serpentine belt to rip off first (I would think).
Add to cw2899's Reputation
Rate the quality of this post and help cw2899 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cw2899 is offline   Reply With Quote
Old 04-11-2011, 08:38 AM   #8
mikec
mikec will become famous soon enough
mikec's Avatar
Sorry for the repairs needed. For the above poster I would think that $3500 is close to the value of the vehicle. If it was paid off, I would consider parting it out, donating it to charity or giving it to a junkyard.
Add to mikec's Reputation
Rate the quality of this post and help mikec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikec is offline   Reply With Quote
Old 04-11-2011, 09:50 AM   #9
Chazberry
Chazberry's Avatar
1995 SW2
There's been at least 2 reports of shredded Serp Belts getting under the Timing Belt Cover. Seems hard to believe, but apparently it happens. I think I better replace my leaking A/C Compressor before it siezes.
Add to Chazberry's Reputation
Old 04-11-2011, 10:15 AM   #10
cw2899
2 things...first my apologies for the spelling errors in my last post. And second, I have to wonder how the AC compressor "siezes" and causes the timing belt to shear apart. I would think the serpentine belt would "squeal" and come off before the timing belt would come apart. If anyone can make sense of this for me it would be appreciated. Oh yea, I did notice a rattle noise that was getting louder ever since the timing belt was replaced. It sounded to me like the belt was rattling inside the timing cover and would make more noise with increase in RPM. So I wonder if the shop screwed something up.
Old 04-11-2011, 11:29 AM   #11
Chazberry
Chazberry's Avatar
1995 SW2
What I believe happens is: the Serp Belt fails -for whatever reason -and pcs get inside the Timing Belt Cover and then get under the Timing Belt which causes it to jump some teeth. Did they replace your Tensioner and Idlers when the Timing Belt was replaced?
Old 04-11-2011, 11:54 AM   #12
cw2899
Thanks for the reply! Yes, when they did the timing belt they also replaced the tensioners, waterpump and new serpentine belt.
Old 04-11-2011, 12:18 PM   #13
Someclown
Someclown is on a distinguished road
Someclown's Avatar
2002 VUE 3.0L
Sounds to me like they did screw something up like not doing the proper adjustment on the tensioner before torquing the bolts (hence the rattling)
sorry about your loss.
Add to Someclown's Reputation
Rate the quality of this post and help Someclown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Someclown is offline   Reply With Quote
Old 04-11-2011, 12:45 PM   #14
Chazberry
Chazberry's Avatar
1995 SW2
Maybe too coincidental that the A/C Compressor would fail right after the Timing Belt was installed. I don't suppose they showed you the seized unit?
Old 04-11-2011, 01:01 PM   #15
Someclown
Someclown's Avatar
2002 VUE 3.0L
I believe the serpentine belt would burn off before the timing belt with a seized compressor , Im sure the serp. belt would spin on the compressor pulleye
Coincidink maybe !!
A way out for the mechanic or shop from having to pay for the damage probable
I dont recall ever hearing of a compressor seizing but others may know better than myself about that
Old 04-12-2011, 12:36 PM   #16
cw2899
Yea, it is very "odd" and I can guarantee I will demand to see the old compressor. Especiallly since it was not making any noise before I brought it into the shop. And the noise I heard was too much like a timing belt slapping the inside the cover to me. And when I mentioned it they said it was "a noisy compressor". Regardless, guess I will be driving the vehicle for quite a while to recover the expense.
Old 11-11-2018, 07:35 AM   #17
Bamman90
Bamman90 is on a distinguished road
It seized because the new serpentine belt and tensioner pully put much more force on the pully system that a already weak a/c failed under the tension. Makes alot of sense this would happen.
Only reason I created an account was to explain this since noone had an idea
Add to Bamman90's Reputation
Rate the quality of this post and help Bamman90 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bamman90 is offline   Reply With Quote
Old 11-11-2018, 09:08 AM   #18
atikovi
Joined just to revive a 7 year old topic?
Add to atikovi's Reputation
Help! - Timing Belt L81 - AC Delco -Rock Auto Kit - Timing Mark Question oldvue Vue Tech 5 09-16-2010 04:55 PM
does broken timing chain damage valves? schreckman S-Series Tech 8 05-12-2009 10:30 AM
2001 LW200 Timing Chain Failure - Head Damage fish_skier L-Series Tech 10 11-30-2008 10:46 PM
Timing Chain or Timing Belt SL1/SL2 MikeJeffcoat S-Series Tech 1 06-21-2006 09:02 PM
SL1 engine question: Non-interface design? (Timing chain failure cause head damage?) rtfm17 S-Series Tech 7 08-06-2003 02:41 PM
