Old 04-18-2007, 06:47 PM   #1
Nomad2day
Nomad2day is on a distinguished road
1991 SL2
Default Sunroof rear drain tubes ends at????
I have a 91 SL2 4 door with a sunroof. Yes it leaks and the passenger rear side drain tube is clogged up. I blew some compressed air through it and thought it cleaned it out. I tried to blow through it but it is still clogged. Where is the end of it??? I found the front ones on both sides and cleaned the slits on the bottom, but I have no idea where the rear ones end up. I have pulled all the plastic interior pieces out, the back seat and looked under the rear wheel well plastic piece. Someone please clue me in where to find the end of it so I can clean it out.
Thanks in advance,
Neil
Nomad2day is offline   Reply With Quote
Old 04-18-2007, 08:34 PM   #2
dcp
dcp is on a distinguished road
dcp's Avatar
Default Re: Sunroof rear drain tubes ends at????
Im not sure,but I would like to know also
dcp is offline   Reply With Quote
Old 04-18-2007, 09:23 PM   #3
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
If it's like my 97 SC2 they are inside the trunk. The ends of the tubes are pressed into the side panels behind the rear wheels.
Current Fleet:
97 Black Gold SC2 Manual
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
00 Yamaha SUV1200 Waverunner
blackeagle1 is offline   Reply With Quote
Old 04-18-2007, 09:42 PM   #4
Nomad2day
1991 SL2
Figured it out after reading some archives to point me in the right direction. On my 91, all I had to do was pull the rear fender top attachment bolt by the rear door. I broke the plastic rivet if that is what attaches at the very top. I did not know it had a bolt head inside the rubber head when I started. When I removed that one bolt I could pull back the top of it and there was a back plastic enclosure with the rubber tube end piece in it. I was able to pull it all out from there.
My problem was the tube had a S bend in it and was collapsed on itself. When I blew compressed air it would open up under the pressure but return to the S shape a totally close after that. Loks like they had too much slack in the rubber hose when they installed it and it collapsed on itself.
Old 04-18-2007, 10:33 PM   #5
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Nicely done..I applaud your effort. Did you replace the hose or were you able to reposition it?
SaturnTech is offline   Reply With Quote
Old 04-19-2007, 07:01 AM   #6
Nomad2day
1991 SL2
I was able to cut off the crimped part and then slide it back into the end piece which is a couple of inches long and it holds it straight where the walls may have memory in them from being kinked. I was able to cut it back a cuple of inches.
Neil
Old 04-19-2007, 10:10 AM   #7
PurdueGuy
PurdueGuy's Avatar
1999 SC1
that's only 2 out of 4 drain tubes... the others end behind the trim in the front seat foot wells.
Old 04-19-2007, 10:23 AM   #8
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Some people might find this usefull when searching sunroof problems. I uploaded it to our site a few months ago.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 04-19-2007, 12:44 PM   #9
richpin06
richpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nice
richpin06's Avatar
I was out and about today so i stopped in at the local pick-a-part.Went in took off the rear fender of a 97 SL2 to give people a good look at the rear sunroof drain location.
Old 04-20-2007, 07:06 AM   #10
Nomad2day
1991 SL2
Good pictures and info,
Thanks richpin06 for the actual pics. Tells the whole story.
Low Saturn, On a search I did not see that but it would of pointed me right to them.
Thanks to everyone
Seems like they need to make a sticky in the forum on the drain tube locations or a sunroof/moonroof section.
Neil
Old 11-16-2014, 09:16 PM   #11
stephenc
stephenc is on a distinguished road
I tried running a wire through the rear drain tube to clear it up. But the wire would not go all the way through. The tube was obviously kinked. Fortunately, I had some stiff tubing left over from a reverse osmosis water filtration system I installed. This tubing was less than half the diameter of the drain tubing. I inserted the reverse osmosis leftover tubing into the Saturn drain tubing and this should prevent it from kinking again. I hope someone finds this post useful. Seems like there are very few Saturns left on the road now days. Every week, I get updates from Pick and Pull telling me there are a Saturns that just arrived in their yard. :-)
stephenc is offline   Reply With Quote
How do you get to the front sunroof drain tubes? demoncamber S-Series Tech 6 10-10-2009 08:22 PM
Sunroof Drain Plug beensmoked L-Series Tech 1 02-03-2005 02:18 AM
Location of sunroof rear drain plugs on 4dr SL2 SL296Guy S-Series General 4 01-21-2005 05:04 PM
Sunroof drain hose gunny S-Series Tech 2 02-12-2002 05:41 PM
Large Rear Ends SaturnBeliever General Saturn Discussion 4 08-28-2000 07:53 AM
