Old 11-23-2023, 12:36 PM   #1
Bessarion
Bessarion is a jewel in the roughBessarion is a jewel in the roughBessarion is a jewel in the rough
2003 ION-2 Sedan
Default 2003 Ion 5spd Clutch problems.
My son told me that when driving in 4th gear, he was unable to shift into neutral. So he floated it into neutral using speed/RPMs, and when trying to shift into third, he heard a pop and then clutch pedal went to the floor. Now he is able to shift, but has no feedback from the clutch pedal as to when the clutch "bites," and he still has problems sometimes shifting from/to third and fourth. Anybody has any ideas? My feeling is a torsion spring in the clutch disc likely went. Other possibility is one of the splines in the pressure plate snapped, and finally, he may need a new master/slave cylinder.
Anybody has any other ideas?
Bessarion is offline   Reply With Quote
Old 11-23-2023, 10:00 PM   #2
Anduu
Anduu is on a distinguished road
Anduu's Avatar
2005 ION-2 Quad Coupe
Default Re: 2003 Ion 5spd Clutch problems.
Any problems getting into first from a stop?
The easiest thing to rule out is the master cylinder. They are easy as pie to change out.
I'm not totally convinced that is the problem though. As long as there is no load on the transmission it should be easy to pop it out of gear.
The hole the clutch hydraulic line goes through to the slave is big enough to insert a boresope. You could observe the slave cylinder and springs to see if they are ok.
Other than that you would be looking at a transmission out scenario to dig any deeper.
Anduu is offline   Reply With Quote
Old 11-23-2023, 10:57 PM   #3
Bessarion
2003 ION-2 Sedan
Thanks!
2004 Vue 2.2L 5spd - Clutch Safety Switch ejscarfo Vue General 5 02-23-2015 08:02 PM
2003 Ion 1 AF23 5spd Transmission jkenley Ion General 2 10-06-2010 07:15 PM
Huge bill on 2003 Vue 4cyl. 5spd. saturnsalesman Vue Tech 13 03-31-2008 06:18 PM
2001 L200 5spd clutch issuue lebras L-Series Tech 18 02-26-2006 03:32 PM
Severe Hesitation 2003 2.2 5spd Igneouss Vue General 11 12-28-2005 08:58 PM
