Old 09-26-2023, 08:46 PM   #1
lisa1126
lisa1126 is on a distinguished road
Default F 5 Connector replacement
Hi, so my 99 saturn sl2 (automatic) is suffering from the infamous F5 problem. I've located a replacement cabin fuse box and I am wondering if I need to change the connector on the end of the F5 wire or if I can just clean it and respring it.
lisa1126 is offline   Reply With Quote
Old 09-29-2023, 02:00 PM   #2
Signmaster
Default Re: F 5 Connector replacement
I'd probably just clean it up and inspect it. The connectors are usually fairly tough, and unless it seems brittle when you respring it then it should probably be just fine.
Being you've dug enough to find the issue and causes, I'm sure you won't be putting too much load on it in the future regardless. I'm not a fan of the spade connectors, but they found their way into quite a few cars.
At least on the Saturn it's an internal connector. I just played with a Mazda 3 that uses them on the starter of all things. Cleaned up and resprung it once the starter tested good.
Old 09-29-2023, 03:14 PM   #3
lisa1126
Thank you, I'll do that!
Old 09-29-2023, 05:09 PM   #4
Mister_Cee
Mister_Cee is a jewel in the roughMister_Cee is a jewel in the roughMister_Cee is a jewel in the roughMister_Cee is a jewel in the rough
1996 SW2
Signmaster,
It's not often (like never before?) I've seen Mazda3 and Saturn mentioned in the same post. How do the two compare?
Mister_Cee is offline   Reply With Quote
Old 10-25-2023, 04:33 PM   #5
Mr_Infamous
Mr_Infamous is on a distinguished road
So I have this 100 watt converter that I've been using all year to charge my stuff. Last night, I started my 99 sl2 and it was running for like 2 minutes while I untangled the charger wires. I plugged the thing into the lighter socket and after about 5 seconds noticed that the red light hadn't turnt green like it normally does. Then, I smelled something burning and the car gracefully shut off. The door locks, seatbelt indicator, chime, and overhead light no longer function and turning the key does nothing except make the instrument panel lights dim slightly.
I found another old post on this with directions, but it might as well be written in Egyptian hieroglyphics because I have no idea what almost any of it means. The driver's side doesn't have the kick guard panel or whatever it's called, it never has, and I can see the back of the fuse box (or whatever the damn thing is called) and a brown soap bar sized box thing and another relay sticking to the back.
https://imgur.com/a/3vsgffm
Is that where my problem likely is? Oh yeah and another thing that I didn't see mentioned here or in the other post: my obd scanner isn't getting a connection either.
Mr_Infamous is offline   Reply With Quote
Old 10-26-2023, 11:36 AM   #6
Signmaster
Slow down and do some searches to find the threads with photos. Once you find the right photos it will make more sense.
https://www.saturnfans.com/forums/sh....php?p=2090693
https://www.saturnfans.com/forums/sh...ghlight=power#
As for the OBD port, I'm not sure on the Saturn, but on later GM vehicles the same circuit powers the OBD port.
Originally Posted by Mister_Cee View Post
Signmaster,
I saw this not long after you posted and forgot to respond. If I get some time maybe I'll post some comparison notes.
Old 10-26-2023, 07:33 PM   #7
Mr_Infamous
Thanks, I've been extremely ill until earlier today so I wouldn't have noticed until now anyway. By the way, before I forget again, in case this turns out to have been my problem, i wanted to add that in addition to the obd port not working, assuming my scanner didn't happen to coincidentally break - I don't have another car in which I can test it - the passenger mirror controls have no effects.
Old 10-26-2023, 08:21 PM   #8
Mr_Infamous
https://imgur.com/a/igHL1Eh
Since I can't find a video of someone actually removing it, I have to ask what I'm supposed to do about that giant cluster of wires blocking my access to the 8mm bolt thingy. I took a screenshot of richpin's video showing how it looks much different than mine. Since nobody mentions how to get it out of the way without breaking anything, I'm wondering if its not actually supposed to look like it does.
Old 10-26-2023, 09:43 PM   #9
billr
The wires are flexible. Move them out of the way to get to that screw. Getting to the screw holding the connector is the easiest part of this job. If it proves too challenging, then I suggest you take this to a professional.
Old 10-27-2023, 07:56 AM   #10
Mr_Infamous
The wires were most certainly not flexible, but that's probably a result of the cheap aftermarket electrical tape they're tightly wrapped in being literally petrified by nearly 20 years of east Texas climate cycles. Anyways, I just decided to use as much force as it took to get the bundle hooked back up where it's supposed to be, and nothing broke.
Once I had access, taking it off was straightforward and after a thorough cleaning, my car is running again! I'm a little worried that the fuel pump is on that circuit... but since the fuse box is in pretty good shape compared to some of the others I saw on F5 problem threads, I can probably fix it by simply doing a more thorough cleaning and tightening the connector... right?
https://imgur.com/a/ZFcv9Q4
Old 10-28-2023, 11:24 AM   #11
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
@ Infamous-
Assuming you were powering your 100W converter from the cigar lighter,
you May have cured the problem, for now.
-> Suggest Do Not power any accessories from the lighter socket, going forward.
If you read enough posts on the F-5 / A-2 issue, you will encounter
work arounds which involve the installation of new circuits in cabin powered by a spare macro fuse in UHJB. Do That - New fused circuit in cabin. Then you can power converter directly from new circuit via spare macro fuse.
As OldNuc commented, the OEM electrical harness is not well equiped for accessory loads.
Old 10-28-2023, 01:04 PM   #12
Mr_Infamous
Originally Posted by TomM96 View Post
@ Infamous-
Yeah, I'm never using the lighter socket again and already am planning on it doing that at the same time I fix the ac. Thanks for the advice!
Old 10-31-2023, 07:11 PM   #13
Signmaster
Some of those wiring bundles get pretty stiff over time, but I'm glad you got it sorted out. It sounds like you may have gotten to it before major melting set in, which is a good thing.
Is your OBD port working again?
Old 11-08-2023, 11:11 AM   #14
TomM96
@ Mr Infamous:
I experienced issue that caused me to open the IP box with F-5 / A-2; in my case existing wiring/connector was AOK.
But I also was concerned about loads on the fuel pump circuit. My 'fix'
was renewing the FP relay with a new item from RockAuto... relay contacts
eventually burn/oxidize, causing increased resistance, and lower voltage
feeding the output/downstream circuit.
electrical issues, f-5, question, saturn sl2 1999
F-5 Connector? Spaghettiohead S-Series Tech 3 11-04-2013 09:22 PM
ABS Connector replacement Jerome99 Vue Tech 3 10-31-2013 12:39 PM
TPS connector replacement? osp001 S-Series Tech 1 04-08-2012 08:53 PM
ECTS connector replacement cvppjp S-Series Tech 8 06-06-2008 01:55 PM
Replacement of the OBD-II connector SirSilentBob S-Series Tech 10 03-17-2008 04:06 PM
