Old 03-31-2012, 02:57 PM   #1
Geos
Geos is on a distinguished road
Default auto > 5-spd swap?
What's a ballpark figure for a automatic to (reman) 5-spd tranny swap incl. parts & labor? I'm looking at a 98 SW2 with auto but I really want a 5-spd.
Geos is offline   Reply With Quote
Old 03-31-2012, 03:27 PM   #2
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Default Re: auto > 5-spd swap?
More than it's worth unless you can get the parts really cheap and swap it yourself. Probably comparable to what the auto SW costs.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
colonelhogan44 is offline   Reply With Quote
Old 03-31-2012, 03:50 PM   #3
Someone that knows what they're doing (has done it before) could probably do it in 5-6 hours. Average mechanic, if they'll do it at all, would probably charge at least a full 8hr day unless they surprise me. My first took 2 weeks but I didn't work on it everyday, had to work in the grass/dirt and it was freaking hot those 2 weeks, was my first project bigger then a brake job.
As for cost:
$60 new flywheel
$130 clutch kit
$150 clutch hydraulic's
~$50 for various clutch specific stuff; brake pedal, clutch pedel, clutch safety switch(not required), reverse light switch pigtail.
~$15 for 3qt's of generic Dexron/Mercron ATF or ~$50 for a gallon of Transynd
~$400 into it before you even get the big part, though specific price's may vary.
Most 5spd's I've seen for sale people want $150-$300. I've sold a couple spare's for ~$75 each 'cause I think it's stupid to charge that much.
Much cheaper/smarter to buy a parts car with working parts you need.
Old 03-31-2012, 06:42 PM   #4
colonelhogan44
Or just drive the auto. They're really not that bad, and the gas mileage hit is rather minimal.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 03-31-2012, 07:02 PM   #5
ssewall
ssewall is on a distinguished road
The auto hurts mileage quite a bit in the winter if you take short trips. This is coming from an auto driver with a scangauge. The torque converter won't lock until it reaches 68 degrees. If it's 10 degrees outside and the engine is cold, this takes forever. I've observed a ~5-8mpg hit from what I'd normally get when the TC locks, ie continuous speed driving. The net impact on mileage from that and warm-up enrichment in the winter is usually around 6mpg for a 5 mile drive.
ssewall is offline   Reply With Quote
Old 03-31-2012, 07:50 PM   #6
colonelhogan44
I suppose that would do it. About 20 mornings out of the year mine takes 1 mile of driving on a real road to lock, otherwise it's already locked before I hit 4th gear. Then again, a bitterly cold winter night here is mid twenties.
Otherwise, I average about 35 mpg in my auto, and maybe 36 in the manuals...but it's usually about the same.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 04-01-2012, 04:52 PM   #7
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Total cost will depend on the shop, but as mentioned, it's likely to be more money than it's worth. It's really not a bad DIY job if you're at all mechanically capable, and the parts cost is generally quite cheap. IMO if you're set on a manual & can't do it yourself, sell the car & buy one with a stick.
SaturnSeries.net owner
auto to manual swap slammedsl2 S-Series Mods 1 06-06-2011 10:24 AM
auto to manual swap.. Mgg4591 S-Series Tech 207 10-28-2010 01:35 AM
99 SL2 PCM Swap (Auto to 5spd) rentfrow1 S-Series Tech 11 05-05-2010 12:09 AM
Auto to manual swap zTagged S-Series Tech 6 04-05-2008 09:43 AM
Auto to manual swap Sisko690 S-Series Mods 11 11-03-2006 03:29 AM
