Old 07-06-2011, 07:19 PM   #1
hotrodtodd
hotrodtodd is on a distinguished road
Default sl1 and sc1 auto transmission swap?
Hello guys,new guy here that has been lurking Saturn forums for the last few months .
My step son started out with a 97 sl1 a while back as a first car,well in the meantime I have been trying to fix it up and make it safe for him.Well a couple days ago he tells me there is something hitting hard under the hood....yup....has a rod knocking. So instead of putting more money in this one he decides to buy another car with his own money,this time it is a 2001 sc1 3 door coupe.
I really like this car and so does he,but bad luck has struck again.yesterday it developed a nasty tranny leak inbetween the engine and transmission. so we took it to a local shop to have them put a new seal behind the converter and go on.Today I stop at the shop to find out that there is a hole in the bellhousing next to where the axle rides behind it! And the previous owner had epoxied a piece of metal over the hole to stop the leak!
So now we have these two cars sitting and I would like to ask the pros if the tranny from the 97 will fit the 2001 and work?
Any help is appreciated.
I am heading back to the shop now so will hopefully get some pics of the tranny.
hotrodtodd is offline   Reply With Quote
Old 07-06-2011, 11:12 PM   #2
campus189
campus189 is on a distinguished road
campus189's Avatar
1997 SL1
Default Re: sl1 and sc1 auto transmission swap?
Someone correct me if I'm wrong but....
97 SL-1 should have SOHC Engine with a MP6 Transmission.
01 SC-1 should have DOHC Engine with a MP7 Transmission.
If your 97 is a DOHC Engine , it will have a MP7 Transmission & you can use it.
1997 Saturn SL2 144,000 Miles
1997 Saturn SL1 254,000 Miles
1997 Saturn SL1 157,000 Miles
1996 Saturn SL1 97,000 Miles
Also known as FiremanCV on YouTube
campus189 is offline   Reply With Quote
Old 07-06-2011, 11:38 PM   #3
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Both cars should have SOHC engines, which means both came with MP6 transmissions- go ahead and make the swap.
hoseppi is offline   Reply With Quote
Old 07-06-2011, 11:39 PM   #4
Wrong on both counts. If the SC1 had a DOHC/MP7, the OP would NOT be able to use it. But the SC1 has an SOHC engine and MP6, just like the SL1. The real question is, did the gear ratios for the MP6 change between '97 and '01? Well, let's dial up them interwebz over to the inestimable Low Saturn's encyclopedic site, specifically to http://www.differentracing.com/tech_...gearratio.html . Aaaaand, D'OH, second gear is different! It would probably throw a P0732, incorrect second gear ratio, code.
Old 07-06-2011, 11:54 PM   #5
campus189
campus189's Avatar
1997 SL1
Should, doesn't mean they do
I got a SL-1 with a DOHC & a SL2 with SOHC.
Checked my VIN to find out both engines were swapped.
Why I stated that..
Need to know if there was a swap at some time.
You never know
Lots of people don't tell you, or don't know
auto to manual swap slammedsl2 S-Series Mods 1 06-06-2011 10:24 AM
Auto to manual swap zTagged S-Series Tech 6 04-05-2008 09:43 AM
Auto to manual swap help alfieferenzo84 S-Series General 2 11-18-2005 04:08 AM
Auto to Manual swap QuickSilverSC2 S-Series Mods 10 11-18-2002 03:09 PM
Auto to Manual Transmission swap. Feasible? Killboy-91SL2 S-Series Tech 10 04-16-2001 05:54 PM
