Old 02-21-2008, 10:13 PM   #1
kim_lombard
kim_lombard will become famous soon enough
Idea Swap 2000 SL2 DOHC (auto) into a 1999 DOHC (manual)?
SO, I'm getting a new project (I'm thinking this is a good idea). I'll want to Swap 2000 SL2 DOHC (auto) into a 1999 DOHC (manual)?
The 99 has a blown engine (previous owners daughter ran it w/o oil - bad daughter) . But the rest is good (only 80,000 miles).
The 2000 is a parts car (salvage title). Engine is good - body looks like it should be sent off to pick-n-pull once I yank the power plant.
I've done two engines, now, on my own. I jumped with glee on the last one when it started on the first try (but I digress from the topic of this thread).
WHAT, IF ANY - ARE THE PITFALLS OF THE SWAP? I'm just trying to get a drivable 99 out of the deal.
Please let me know what to expect.
Thanks, in advance.
This forum has been a life saver.
kim_lombard is offline   Reply With Quote
Old 02-21-2008, 10:21 PM   #2
Default Re: Swap 2000 SL2 DOHC (auto) into a 1999 DOHC (manual)?
What are you swapping? Engine? Tranny? Both?
Old 02-21-2008, 11:09 PM   #3
kim_lombard
Sorry - I'm swapping just the engines. thanks.
Old 02-22-2008, 01:12 AM   #4
asdf
asdf is on a distinguished road
You can put the throttle cable from the 2000 into the 1999 and use the engine as-is, that's probably what I'd do. You will have to unscrew the knock sensor from the 1999 and stick it on the 2000. The hole is already vacant.
Otherwise you can put the aluminum intake manifold on the 2000 engine.
asdf is offline   Reply With Quote
Engine swap: 2000 SL2 DOHC for SOHC mjm S-Series Tech 4 05-05-2009 12:13 PM
Swapped a 2001 SC1 DOHC engine with a 2000 SL2 DOHC now have transmission issues knukklhead S-Series Tech 18 04-13-2009 07:48 PM
2000 dohc to 1999 sohc swap? tc6160 S-Series Mods 4 02-01-2009 10:36 PM
1997 Dohc to 1999 Dohc Engine swap aaronstubbe S-Series Tech 6 10-31-2007 11:41 PM
93 DOHC Conversion and Auto to Manual Swap etc. 92NOSSL2 Classifieds 1 11-13-2002 07:22 PM
