Old 11-25-2010, 01:00 AM   #1
DrEvil
DrEvil is on a distinguished road
Default Hi....Q on a non-working horn
Hi,
I'm not really evil - just get a kick out of Austin Powers.
A friend of mine had the horn fuse blow, replaced it. Fuse has not blown, but horn does not work.
Anyone had this problem? Is it just a fried horn? Would it be a simple replacement and located in front of the radiator?
In advance, thank you.
Add to DrEvil's Reputation
Rate the quality of this post and help DrEvil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DrEvil is offline   Reply With Quote
Old 11-25-2010, 10:12 AM   #2
SLCraig
Default Re: Hi....Q on a non-working horn
When I bought my first Sat a few years ago it had a non functioning horn.
I also had a blown fuse.
After I replaced the fuse, the horn still did not work.
I replaced the horn with one from the wreckers and life was good again, did not have to replace the fuse twice.
I guess when they go, they have a tendency to wipe out the fuse as well.
The horn just behind the drivers side headlight.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-25-2010, 10:36 AM   #3
Sid
Sid will become famous soon enough
Sid's Avatar
My horn died years ago. I can't recall whether the fuse blew or not. I got a double horn from Harbor Freight and shoe-horned it in. Now my Saturn has a big boy horn.
Add to Sid's Reputation
Rate the quality of this post and help Sid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sid is offline   Reply With Quote
Old 11-25-2010, 11:48 AM   #4
Originally Posted by DrEvil View Post
Hi,
First need to know the year of the Saturn. The Gen-2 cars have a 3 terminal horn which can not be replaced with a parts store part. And, an attempt to do so will cause major problems.
Old 11-25-2010, 11:58 AM   #5
DrEvil
BTW, the Saturn in question is a 1996....I had it on the profile but stating it for clarity.
Is it easy to replace the horn with a generic replacement?
Old 11-25-2010, 12:58 PM   #6
Missed it....
No it is not easy unless you can get an OEM 3 terminal horn from a J/Y. And the usual J/Y testing process kills them. They have a solid state relay inside of the horn and the horn buttons only control a very low current. the actual horn current is through the solid state relay. The horn is in the left fender well way up front. You can see it from underneath which is the easy way to get at it.
This is the wiring diagram of the horn. http://www.saturnfans.com/photos/sho...n-wi/cat/12963
You can replace the horn with a 2 terminal horn and a relay though. Below is a parts list.
You will need a relay with the contact rating of 10amp or a bit more as your horn circuit is fused at 10a which will limit the max current.
This link shows and explains the reason for the diode across the coil. It is also a good idea to place one across the horn also as it will reduce the relay contact burning. http://mrmatix.com/relay-contacts.html
Low cost parts can be found here. http://www.allelectronics.com/
These relays and diode will work and these are the catalog numbers.
RLY 531 720 ohm, 10a/125vAC SPST N.O.
RLY 524 346 ohm, 10a/125vAC SPDT
Diode GI851 3a/100piv
The RLY 531 is probably the best one for a horn relay replacement.
You can wire the +12v to the horn with 18 gauge wire. You can find comparable relays and diodes at Radio Shack and 200 ohms is about as low as you want to go on coil resistance. All you have to have relay wise is a SPST N.O. relay rated at 10a contacts. (SPST = Single Throw Single Pole and N.O. = Normal Open deenergized)
The issue with the coil resistance is to limit the max continuous current that will flow through the horn contacts. Remember, they were designed to only switch the base current of a solid state switch.
And, this post thread, http://www.saturnfans.com/forums/sho...d.php?t=151539 post #13 shows the construction drawing. Might wan t to read the entire thread as it will probably answer the rest of your questions.
The relay and replacement horn is the best approach as the relay will outlast any J/Y horn and will be cheaper in the long run.
Old 11-25-2010, 02:25 PM   #7
Sid
Sid's Avatar
FYI, the Harbor Freight dual horn comes with a relay.
http://www.harborfreight.com/2-piece...set-99911.html
I sure don't remember wiring one in though. I should probably check. Thanks OldNuc.
96 SW2 5MT
Old 11-25-2010, 02:34 PM   #8
If you have a 3 terminal horn then you have a relay. The HF relay will not do the job on a Saturn, don't even try as it is a conventional horn relay and you will burn up the horn buttons.
Old 11-25-2010, 10:33 PM   #9
moresaturn
moresaturn is on a distinguished road
moresaturn's Avatar
1998 SC1
I would suggest getting one out of a Junk Yard (or off me as I have a working 2nd gen horn) as they are much cheaper than a new one which is 50+ dollars. I bought a new one from Getsaturnparts.com and I have no complaints.
If you have access to a Digital Multimeter then look up the horn troubleshooting on Richpin's channel on Youtube, it could be quite resourceful.
1994 SL2 - 24 Hours of Lemons Racecar
1998 SC1 - 305K miles - dead
2001 SC1 - 349K miles and counting - 1 quart per 1K miles - stock engine
Just another OEM engineer...
Add to moresaturn's Reputation
Rate the quality of this post and help moresaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
moresaturn is offline   Reply With Quote
Old 11-29-2010, 05:04 PM   #10
DrEvil
Correction - it's a 1998 SC2.
Does that change the suggestions?
Old 11-29-2010, 05:14 PM   #11
You need a 3 terminal horn either build the replacement or try a J/Y. Most J/Y horns are junk though so get a warranty on it.
Horn not working tom_94305 S-Series Tech 3 08-27-2010 02:05 PM
'02 VUE Horn NOT Working dpware Vue General 7 04-19-2010 02:27 PM
Horn not working hlp plz! Salsa88 S-Series Tech 12 12-28-2007 12:38 AM
Horn not working, which fuse is it? bankerbob S-Series Tech 2 08-14-2006 01:48 PM
Horn not working gunny S-Series Tech 10 08-28-2002 01:52 PM
