Old 04-14-2010, 01:25 PM   #1
dpware
dpware is on a distinguished road
Default '02 VUE Horn NOT Working
The horn on my '02 VUE is not working. This happen after a bout of involuntary honking following a long honk at an aggressive driver. Reading some past threads on this topic, I afraid that I might be looking at a $1000+ horn switch repair because of its location within/below the airbag.
One question. The horn doesn't respond to the remote either. Does this mean it's possibly the actual horn (or fuse) and not necessarily the switch?
Add to dpware's Reputation
Rate the quality of this post and help dpware reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dpware is offline   Reply With Quote
Old 04-14-2010, 02:01 PM   #2
XRL
XRL's Avatar
2004 VUE Red Line
Default Re: '02 VUE Horn NOT Working
It's likely both. It sounds like the involuntary honking was the switched being jammed, and the fuse blew due to the horn being on for so long. It's also possible that the horn itself just went out, but it's likely due to the switch.
Add to XRL's Reputation
Old 04-14-2010, 02:04 PM   #3
far2grumpy
far2grumpy's Avatar
dpware ... I'm with you - I'm not sure the horn switch is the culprit.
Can you follow electrical wiring schematics?
I've attached one for the 02 Vue. You'll note the horn circuit has a horn, fuse, relay, switch and wiring.
You might check the fuse and try to temporarily substitute the relay with a similar one from another circuit. Both fuse and relay are in under-hood fuse box.
Don't despair if it is the switch ... you can add and after-market switch for a few dollars.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 04-15-2010, 10:15 AM   #4
dpware
Is this something my dealer or a local mechanic could (and will) do? Unfortunately it won't be me!
Old 04-15-2010, 12:24 PM   #5
far2grumpy
far2grumpy's Avatar
Unless you know specific reason for horn not working either a dealer or mechanic will most likely charge to isolate.
If the airbag switch is bad: (1) dealer may insist upon replacing the airbag
(there could be exceptions), or (2) mechanic could add a separate switch but might have any number of liability disclaimers.
If you want to try - or know someone with basic electrical/mechanical skills - you can find rework info in following thread (post # 9 advises how to find wires for new switch):
http://www.saturnfans.com/forums/sho...d.php?t=150296
Old 04-15-2010, 01:44 PM   #6
dpware
Thanks. I can't do it, and I'm not sure I know anybody I could convince to do it either. First thing, I'll get it to the dealer to be diagnosed. Hopefully it will just be a fuse or relay and I won't fall victim to the thoughtless engineering by the General of the horn switch!
Old 04-16-2010, 05:02 PM   #7
VTchemist
VTchemist's Avatar
A workaround may be the installation of a horn switch on the steering column. It's cheaper that replacing the airbag.
One poster describe placing switches on the airbag assembly. Bad Idea.
If the airbag deploys, he will have two new piercings...
Get your dealership to confirm the airbag is OK. Then, you can rewire a horn button.
Hope this helps a bit..
Add to VTchemist's Reputation
Rate the quality of this post and help VTchemist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-19-2010, 02:27 PM   #8
dpware
OK. So, had a friend check things out. Fuse for horn was blown. Replaced that, but now it seems like horn is blown too. Only making a weak buzzing.
Going to grab a replacement horn on the way home and have friend install it. One question, maybe a dumb one. I see that there are low note, high note and combo horns. What does the VUE have? Thanks!
Horn stopped working scott2683 Vue General 2 01-21-2010 11:10 PM
Horn not working hlp plz! Salsa88 S-Series Tech 12 12-28-2007 12:38 AM
Horn not working, which fuse is it? bankerbob S-Series Tech 2 08-14-2006 01:48 PM
Horn button not working Lee3333 S-Series Tech 3 06-13-2005 09:47 PM
Horn not working gunny S-Series Tech 10 08-28-2002 01:52 PM
