Old 08-11-2021, 11:05 AM   #1
Mattmoosh
Mattmoosh is on a distinguished road
2004 VUE 3.6L
Default 2004 saturn vue front cradle subframe/frame bushing
I have found a welder that is willing to retrofit the front Cradle mounts. They have rusted out...
My question is what are the part numbers and or names for the bushings and bolts that need to be replaced?
They sit between the subframe and frame. The welding shop will install them if I can get them.
They can get them for added cost, but I need to be a bit frugal.
Thanks for your help!
Mattmoosh is offline   Reply With Quote
Old 08-11-2021, 09:14 PM   #2
waiter21
2003 VUE 2.2L
Default Re: 2004 saturn vue front cradle subframe/frame bushing
I assume this is what you're referring to:
https://www.1999southwind.com/toad-2...#ENGINE_CRADLE
Old 08-12-2021, 09:10 AM   #3
Mattmoosh
2004 VUE 3.6L
This is what I am talking about. Mine seems to have a bushing that goes between the frame and subframe. He seems to have replaced it with the square tube stock, I guess.
Old 08-12-2021, 11:32 AM   #4
waiter21
2003 VUE 2.2L
I replaced the engine cradle on mine a few years ago. found one in Texas that had zero rust.
http://www.saturnfans.com/forums/sho...d.php?t=234668
Old 04-25-2023, 02:54 AM   #5
tonyadams
tonyadams is on a distinguished road
For the front subframe mount bushings on the 2004 Saturn Vue, some frequently used item numbers are: Moog K200132 Energy Suspension 7.1108R or 7.1108G, AC Delco 15211402. To get the right bolt specs, you might need to reference the manufacturer service manual for the Saturn Vue or speak with a dealer or auto parts retailer. To ensure that the subframe fits and operates properly, it's crucial to use the right bolts.
io games
tonyadams is offline   Reply With Quote
Old 05-23-2023, 03:25 AM   #6
Coma197
Coma197 is on a distinguished road
tiny fishing
yebb, that's right. Using the right bolts is very neccessary.
Coma197 is offline   Reply With Quote
Old 06-11-2023, 11:16 PM   #7
bekean
bekean is on a distinguished road
http://www.saturnfans.com/forums/sho...d.php?t=234668 fnf
Visit local automotive parts stores in your area and provide them with your vehicle details. They should be able to assist you in finding the necessary bushings and bolts. It's a good idea to call ahead to check if they have the specific parts in stock or if they can order them for you.
bekean is offline   Reply With Quote
Need Front subframe (engine cradle) for 1993 SL1 SOHC 4door 93 SL1 Canada Classifieds 2 01-01-2021 03:14 AM
Anyone in the Houston area have a decent front engine cradle/subframe for a 2002 SL1? Doug427 S-Series General 4 11-30-2018 11:56 PM
Rusted Front Subframe / Engine Cradle Rivernut Vue Tech 7 03-07-2013 12:59 PM
subframe/cradle quantumech S-Series Tech 2 11-05-2010 01:00 PM
saturn cradle/ subframe help daveisdiving S-Series Tech 8 06-03-2009 11:45 AM
