Old 11-03-2022, 10:35 AM   #1
akshat
akshat is a jewel in the roughakshat is a jewel in the roughakshat is a jewel in the rough
Idea Vue '06 3.5L All lights flickering. Battery and Alt replaced 4 months ago
The alternator died on this 2006 Vue 3.5L around 4.5 months ago. It took the battery with it, and so I had both replaced.
I didn't have my tools at the time, so the alternator was done by a decent mechanic (though they said they used an O'Reilly alternator — I feel like I've heard talks about auto part store alternators being finnicky with the Vue). The repair looked like a decent job, and the car battery was being charged so I had no complaints.
The battery I replaced myself with a Walmart battery to spec. I got the felt pads, cleaned the terminals and tightened to spec with a torque wrench and added battery terminal grease. I've looked at the connection and it is still tight, hence I find it unlikely that the battery is the problem.
The issue I've recently noticed is that when the engine is turned on the lights on the dashboard, headlights, and interior lights are all flickering. I installed an aftermarket touchscreen stereo but it does not flicker (I believe it has some circuit to prevent voltage fluctuations to hinder performance).
https://youtu.be/I9PIoP4HMb4?t=59 This video is exactly what the interior and exterior lights of my car look light, only when the engine is turned on. With acc power, everything operates normally.
What I've currently tested:
1. Visual inspection of terminals + connections
=> Terminals on battery and alt look good.
2. Test alternator by checking battery voltage with engine running
=> Battery reads 14.3-14.5 V with alternator running.
As I haven't had much time these are the tests I still need to perform:
1. Check battery voltage at rest
2. Check engine ground connections (test resistance < 5ohms) starting with battery, alternator, other parts of engine.
3. Clean and double check alternator connections (Just in case)
4. Check DTC codes
If none of this works I'll head back the the mechanic and ask them to take a look, but if there's a relatively easy fix I'd like to try that first. A part of me thinks that it might be the alternator they used. Initially I bought an Denso 210-0546 remanufactured alternator but it ended up being broken on arrival so the mechanic just ordered one from O'Reilly and replaced it. I've read things about Vue's not working in the cold with some alternators that have bad voltage regulators/are rated for 130amps instead of 110amps. Since it is getting cold where I live, I have a feeling this could be the issue, but I want to really get a good look at issue and give my mechanic the benefit of the doubt that they installed a decent alternator.
If anyone has any advice or tips for this issue, I'd love to hear them.
Edit to add:
I just found this video: https://youtu.be/iprTa84MeFc and the flashing looks like a much more exaggerated version of my situation (For my actual situation you can see the first video). Since it has only just started getting cold and currently around 10C (50F) where I live, maybe this is indicative of what is to come when it gets colder. The video specifies that the issue is a bad voltage regulator on an aftermarket alternator, and so it's looking more likely that this is my issue as well.
Last edited by akshat; 11-03-2022 at 10:41 AM. Reason: Added new information and video that I found about the issue.
akshat is offline   Reply With Quote
Old 11-03-2022, 09:48 PM   #2
Default Re: Vue '06 3.5L All lights flickering. Battery and Alt replaced 4 months ago
Search past threads about replacement/rebuilt alternators for Vue 3.5L engines. For whatever reason, the solid state regulators used in every alternator for every make and model in the world are fine except 3.5L Vues. Past threads here discuss it with original GM regulators recommended for repair, rebuild or factory new (if not discontinued).
To eliminate any chances of poor main power connections from years of weathering, road salts and general wear and tear, check three(?) main power connections (both ends); battery positive between battery and starter, battery negative between battery and chassis, and chassis to engine block. There may be rain water infiltration into a multiple pin connector by driver's door sill (also in past threads) creating corrosion to electrical connections.
The first link showing how to measure ac ripple voltage leaves out reference values. In general, alternators should output no more than around 20-40 millivolts, ac (0.020-0.040 vac). The higher voltage suggests the replacement alternator is faulty.
The second link seems to address Vue 3.5L alternators. However, in general, all alternators are designed to operate with a wide temperature range, between subfreezing Arctic and desert heat, including underhood engine temps. All temperature and voltage regulation performed by solid state electronics.
Old 02-01-2023, 01:18 PM   #3
Mayora
Mayora is on a distinguished road
I am going through the same thing ATM. But when pulling the alternator the mechanic snapped the ac compressor bracket so now I don't know what to do.
Mayora is offline   Reply With Quote
Old 02-01-2023, 02:51 PM   #4
akshat
Alt Update!
Turns out the alternator that the mechanic used was faulty. Apparently this is an issue on the Saturn Vues of this period as there needs to be a specific voltage regulator for cold temperatures on the alt. There are a lot of aftermarket alts that meet the spec for this car, but don't include that necessary circuit.
My mechanic got another alternator and fixed the issue for free (as they were the ones that installed the faulty one in the first place).
The new alternator has been running well for a month or so now and there's no issues.
@Mayora, your mechanic should fully cover any costs associated with things they broke
alternator, flickering lights, pulsing lights, vue 06, vue 06 3.5l
Battery replaced- now the dashboard lights up like a Christmas tree! BLH RS4TC 4040 Aura General 5 06-19-2018 03:33 AM
Flickering Battery Light. New Alt/Battery Carbon.Beatz L-Series Tech 19 04-25-2015 03:42 PM
replaced battery - no dash lights, radio, etc.. fjcsr Relay General 1 10-10-2012 10:48 PM
2001 Sc1. Service wrench & security lights on after battery replaced. bowler484 S-Series Tech 8 10-10-2006 08:54 PM
Battery Light flickering Qlara S-Series Tech 27 01-20-2002 07:13 PM
