Old 05-03-2018, 06:55 AM   #21
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
Default Re: Head Gasket???
Might want to check with Satlite440 and get his opinion if 'moving on' is a better alternative to replacing the rear head gasket...that is...learn the probability that changing the gasket will resolve the leak in his professional experience. Could also be a crack in the head or block and he would know the probability better than the rest because of his experience. I have heard of no head gasket failures on the 3.6L.
Add to gm7's Reputation
Rate the quality of this post and help gm7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gm7 is offline   Reply With Quote
Old 06-09-2018, 07:25 AM   #22
patrickstapler
patrickstapler is on a distinguished road
2008 VUE 3.6L
Thought I would report back on this. The endoscope is a nifty little tool. Used it a couple of times now. Anyway, I could see where the water appeared to be coming from the rear head gasket. Very small occasional bubbles. I ordered some of the GM “vegetable” tabs. Dropped one of those in a few weeks ago. For now, it’s working. Not sure for how long.
Kind Regards,
Patrick
Add to patrickstapler's Reputation
Rate the quality of this post and help patrickstapler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
patrickstapler is offline   Reply With Quote
#2 Cyclinder plug Gunked up continually, cracked head or leaky head gasket? kewlpop S-Series Tech 13 02-14-2018 05:05 AM
Is it possible to repair a oil leak from the head gasket without replacing gasket? tgferg67global S-Series Tech 13 12-23-2010 08:39 PM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 03:42 AM
Head gasket, head bolts and other head related foolishness… Quagmire S-Series Tech 9 09-12-2007 10:08 PM
cracked head,valve cover gasket or cam gasket leaking ???how to tell !! maestro S-Series General 11 06-04-2006 04:26 AM
