Old 04-27-2015, 11:35 PM   #1
alucard1589
alucard1589 is on a distinguished road
2003
Default Scosche wiring harness
Hi, I'm sorry I opened this thread but I searched the forum and couldn't find anything that helped me, I just bought a JVC stereo for my 03 Ion 1, and I was going to start soldering the cables from the wiring harness to the one from the JVC, but found out that the scosche wiring harness has 3 red cables all labeled ignition/switched, they are at the a2, b4 and b6 locations, I tried looking for a wiring diagram and non of the ones I found mention any of the b's being for ignition so now I'm confused as how to wired the whole thing up, I would really appreciate any help
Add to alucard1589's Reputation
Rate the quality of this post and help alucard1589 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alucard1589 is offline   Reply With Quote
Old 04-28-2015, 10:59 AM   #2
Afrckenway
Afrckenway is on a distinguished road
2003 ION-1 Sedan
2004 ION-3 Quad Coupe
Default Re: Scosche wiring harness
I was having the same issue when I got my wiring harness. The two orange (illumination) wires aren't used iirc. The easiest way to wire the harness will be doing your green and purple wires (the front or rear set) and then your white and grey (second speaker set)
Then wire accessory on (yellow) ground (black) and power (red) and test. If everything works properly you can solder. The unused wires should be covered so you don't ground out and blow a fuse like I did lol.
Add to Afrckenway's Reputation
Rate the quality of this post and help Afrckenway reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Afrckenway is offline   Reply With Quote
Old 04-28-2015, 12:37 PM   #3
alucard1589
2003
Thanks, but I think I'll save me the trouble and just take it to an audio shop for an installation
Old 03-07-2017, 08:31 PM   #4
Seņor Ramos
Seņor Ramos is on a distinguished road
Seņor Ramos's Avatar
2003 ION-1 Sedan
I just got a 2003 Ion 1 and tomorrow my Scosche harness arrives in the mail for the JVC unit I bought. I wonder...why can't I just take the "harness" that's already on the outside of the stock radio and wire that up to the new radio's harness?
1998 Saturn SL1, dark green. His name is Mean Joe Green, and he will rock you. R.I.P.
2003 Saturn Ion 1, silver. His name is Tom Landry, and he's here to stay.
Add to Seņor Ramos's Reputation
Rate the quality of this post and help Seņor Ramos reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Seņor Ramos is offline   Reply With Quote
Old 03-07-2017, 10:44 PM   #5
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
You could do that. The only issue you'll encounter is that not all of the wire colors will match the aftermarket radio. The speaker leads use the standard color scheme, but the power wires do not. The harness on the stock radio that you're referring to is omitted from all wiring diagrams. You'd need to do some testing using a multimeter to figure out which wires are used for constant power and switched power.
Double check to make sure you are getting the correct harness. Some online sources incorrectly specify a harness which is meant to be used with many other GM cars, but doesn't work with Saturns. The correct Scosche harness is GM04B.
2007 Ion 2 Quad Coupe 5-speed manual 178K miles
2007 Chevy Equinox LT 187K miles
Add to ruley73's Reputation
Old 03-08-2017, 08:35 AM   #6
Seņor Ramos
2003 ION-1 Sedan
Thanks. GM04B is the one I bought thanks to the info I found on this site. After I try that out I'm heading back in here if I have any other questions.
Old 03-08-2017, 05:30 PM   #7
Seņor Ramos
2003 ION-1 Sedan
So I need a hand...should I be concerned that there are 2 orange wires (well, orange and orange/white) on the Scosche harness but only an orange/white wire on the JVC harness?
Old 03-09-2017, 03:34 AM   #8
ruley73
ruley73's Avatar
No, this is normal. Just match colors when hooking things up and everything should work fine.
Old 01-24-2018, 10:25 PM   #9
Mgarbers
Mgarbers is on a distinguished road
I am a brand new member to this forum and I need some help I bought a small "tv" touch screen deck to go in my 01 sc2 and I bought the gm04b harness off Amazon and when I hooked it up it won't work I blew a fuse and fixed that but my deck still won't turn on please tell 're someone can help me with this
Add to Mgarbers's Reputation
Rate the quality of this post and help Mgarbers reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mgarbers is offline   Reply With Quote
Old 01-25-2018, 01:24 AM   #10
ruley73
ruley73's Avatar
That is the correct harness for your car. Without knowing anything else, I could only recommend double checking your connections. Which fuse was blown?
Old 01-25-2018, 08:04 AM   #11
Mgarbers
It was on my fuse panel that was on the passenger side by there left leg and if your looking at the panel it was on the bottom right there is a roll of two at the very bottom then a roll of three fuses right above that and it was the fuse that was all the way on the right
. . it was in rows like these dots it was the top right it was a mini 10
Old 01-25-2018, 02:10 PM   #12
ruley73
ruley73's Avatar
In a 2001 SC2 that is the RADIO (BAT1) fuse (10A). Again, double check your connections. That harness is meant for use in multiple Saturn models which use slightly different connections.
Need to buy wiring harness jes Ion Tech 2 01-12-2012 04:23 PM
Help with wiring harness blue98sl2 S-Series Tech 6 06-24-2008 11:18 AM
Scosche GM04B Wiring Harness- Unopened $10 shipped VUEnumber1 Classifieds 1 07-29-2005 08:50 AM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 04-30-2005 11:45 PM
wtb wiring harness 92sl2turbo Classifieds 0 08-24-2004 08:01 AM
