Old 03-21-2001, 03:13 PM   #1
PSU_92
PSU_92 is on a distinguished road
Default 97 SW1 Rear Wiper Washer
I have a 97 SW1. The rear washer has stopped responding to the switch on the stalk. (ie: Activate the switch and there's no motor noise). There's plenty of fluid in the resovoir.
I have scoured my manual, and don't see which fuse (either underhood or by passenger side) is for the rear washer or wiper assemblies on a SW.
I also see no way of removing the body panel to test the wiring at the washer pump, or to see if the washer pump is dead. Saturn of Devon (PA) wouldn't give me any drawings, says the techs are trained on panel removal in TN and don't have time to talk to me, and it's basically an investigative process without definitive times (and therefore non-definitive costs).
I'd like to exhaust my options before bringing the car into the dealer. Does anyone have links show me how to remove panels in the back of the SW? How about wiring for the rear of the SW? (I checked a Chilton's, which has block diagrams, but doesn't identify any particular fuses...)
Thanks in advance.
Add to PSU_92's Reputation
Rate the quality of this post and help PSU_92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PSU_92 is offline
Old 03-21-2001, 10:12 PM   #2
sattech
sattech is on a distinguished road
Default
If the rear wiper works the fuse is good. The fuse is the sun fuse in the IP fuse panel. I'v enever replaced a rear washer motor yet. The easiest way to check it would be at the switch. remove the cover behind the steering wheel. Locate a gray six pin connector. going to the multifunction switch. Term B is a Dk green wire. It supplies power from the switch to the washer motor. Term C is a white wire. It supplies power from the switch to the rear wiper motor. Term D is an orange wire. It supplies power from the fuse to the wiper switch. The wiper and washer ground are the same, the left rear body ground.
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
Old 03-21-2001, 10:50 PM   #3
Default
Chances are that the green wire at the combination switch (multi function) has broken off from its solder joint. Look in behind/through the hole by the stalk and you should be able to see the wire. You should be able to see if it has broken off or be able to GENTLY probe to see if it is loose. Two cures, replace switch assembly or try to resolder the wire. It may be something else but I have seen enough of the wires loose to check there first.
Add to ssicarman's Reputation
ssicarman is offline
Old 03-22-2001, 10:17 AM   #4
PSU_92
Default
Thank you Sattech and Ssicarman for your replies. I'll try to dig into it this weekend.
Mike (PSU_92)
PSU_92 is offline
Gen 1 Wagon Rear Wiper/Washer Question carlbo S-Series General 3 09-09-2008 11:51 PM
Rear Wiper on SW1 not on window and only sometimes works scr390 S-Series Tech 3 08-22-2008 09:42 PM
Rear Window Wiper/Washer Steamrunner 2008 Vue 7 11-28-2007 01:27 PM
Rear washer on 99 SW1 VWman S-Series Tech 2 02-04-2006 06:51 PM
WTB: rear wiper motor for 97 station wgn SW1 97sw Classifieds 1 05-02-2005 01:30 PM
