Old 05-01-2006, 05:52 PM   #1
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
Default wheel studs
i got a 06 ion2 coupe no abs front disk rear drum and i was wondering the size and thread and any other things i will need to know to find a replacement stud for my car ive looked around asked all the local places about info on studs i even called saturn they couldnt tell me the size or anything about them just the part #... broke off 3 already and i dont want to pay saturn $12 a stud because i want to replace all the front ones with upgraded studs rather than factory... thanks joe
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 05-01-2006, 10:04 PM   #2
cfwperks
cfwperks is on a distinguished road
2003 ION-3 Sedan
Default Re: wheel studs
Hey Joe, I have a 2003 Ion 3 , I have broken off 4 rear studs, turns out They are the same as the 2005 Cobalt, the cavalier and some sunfires, unfortunatly I could only get them at the dealer, around $8.00 Canadian,
good luck!!
Add to cfwperks's Reputation
Rate the quality of this post and help cfwperks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cfwperks is offline   Reply With Quote
Old 05-01-2006, 10:14 PM   #3
cfwperks
2003 ION-3 Sedan
Hey Joe!
This is my second attempt at replying to your message, I hope it reaches you, I have a 2003 Ion3, I have had to replace 4 wheel studs, unfortunatly I could only get them at the dealer, $8.00 Canadian each, however they are the same as the 2005 Cobalt, the cavalier and I believe the sunfire, I am now sporting 2005 Cobalt studs. If you need nuts, don't be fooled by the dealer price of 15.00 each, there are many after market deals, I got 4 for less than $10.00 Canadian, tax in!
Good luck!
Old 05-02-2006, 09:00 AM   #4
tlg
tlg is on a distinguished road
tlg's Avatar
2006 ION-3 Quad Coupe
How are you breaking so many studs? I'd be livid if I broke one, let alone 3 or 4. I've done my own wheel/brake maintenance for 16 years and have never broke a stud.
Are you using a torqe wrench? If so, then your studs on an '06 should be covered under warranty.
If you're not using a torque wrench I'd suggest this as a wise investment Craftsman Torque Wrench, 1/2 in. Drive
At only $48 it's about the same cost as what you've already got invested in wheel studs. Your lugs will be properly torqued, plus it has many uses all around your vehicle.
Add to tlg's Reputation
Rate the quality of this post and help tlg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tlg is offline   Reply With Quote
Old 05-02-2006, 02:41 PM   #5
06_Ion2
06_Ion2's Avatar
the reason is i forgot to take off those metal rings around 2 of the studs and the rims didnt fit flat so they didnt fit on flush on 2 of the studs so they vibrated and finaly broke i guess its a lesson learned and i did torqe them to 85 im not retarted i just didnt know those little rings would make that big of a diff because they were already on there with the stock tires so i just left them.. after i did some research i found out that i was suposto remove them by that time it was 2 late oh well...
Old 05-07-2006, 10:07 PM   #6
placid warrior
placid warrior is on a distinguished road
placid warrior's Avatar
stock wheels and some aftermarket wheels are recessed where the clips are although i have seen multiple cars scome in with AM wheels without the recess and havent had a problem although we make sure to remove the clips before reinstalling the wheels. Did u make sure u retorqued your wheels after 100km and then after another couple hundred? New wheels should be retorqued a couple times before they get "broken in". Also u can torque up to 100lbs on the domestics 4 lug or not.
Add to placid warrior's Reputation
Rate the quality of this post and help placid warrior reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
placid warrior is offline   Reply With Quote
Old 05-09-2006, 05:56 AM   #7
06_Ion2
06_Ion2's Avatar
yea those little washers did enught movement to make the studs brake off oh well i guess its a lesson learned ....
Wheel studs FearsOfWar S-Series Tech 6 01-04-2010 01:38 PM
engine mount studs - how to know. colonelhogan44 S-Series Tech 4 12-09-2006 09:26 PM
ball head studs Zorak S-Series Tech 0 02-08-2005 01:57 PM
wheel studs swoker183 Ion General 3 10-08-2004 01:35 PM
Wheel Studs StylinSat Miscellaneous Tech 13 10-16-2002 10:55 AM
