Old 11-14-2005, 04:00 PM   #1
friskyspatula
friskyspatula is on a distinguished road
1997 SL1
Default Crankshaft Sprocket Retainer Tool
Ok, I have given in to the fact that I am going to need to replace the head on my wife's 97 SL1, it seems to be somewhat common problem. I am now part way into dissassembly and all of my references state I need a Crankshaft Sprocket Retainer Tool to take off the timing chain cover. Do I really need this? Or, can I take the cover off without it? I have rebuilt some motors but they were all old school V-8's. I need some advice from you folks who have already done this on the 1.9.
Thanks
Add to friskyspatula's Reputation
Rate the quality of this post and help friskyspatula reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
friskyspatula is offline   Reply With Quote
Old 11-14-2005, 04:38 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Crankshaft Sprocket Retainer Tool
I did my timing chan without one. I've see a post on here that said you can cut the bottom out of a 35mm film cannister and use that.
Add to BarnOwl's Reputation
Old 11-14-2005, 08:34 PM   #3
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
I've done two without it. I think it might help keep the oil pump gear lined up with the crankshaft.
Add to blackeagle1's Reputation
Rate the quality of this post and help blackeagle1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackeagle1 is offline   Reply With Quote
Old 11-15-2005, 05:41 AM   #4
eljefino
eljefino's Avatar
1995 SW1
The oil pump and crank never lined up for me, after priming the oil pump, and turning the engine over to confirm timing. Just stick your fat fingers in the oil pump (=) shaped thing and spin it around till it lines up. The crank sprocket doesn't really go anywhere the timing chain holds it and I don't see a problem if it does slide out a bit.
Add to eljefino's Reputation
Old 11-15-2005, 08:02 AM   #5
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Thanks
Don't need it....never used it. Line the oil pump up by hand when you reinstall the cover.
Add to SaturnTech's Reputation
Rate the quality of this post and help SaturnTech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech is offline   Reply With Quote
Old 11-15-2005, 12:55 PM   #6
friskyspatula
1997 SL1
Thanks for the info everyone, I really appreciate it.
Crankshaft Learn Procedure (no scan tool) gruvn S-Series Tech 25 09-21-2009 11:09 PM
Need pic of cam sprocket retention tool and valve spring removal tool sr20fd3st S-Series General 2 07-13-2009 10:41 PM
sc1 crankshaft gear retaining tool firebug085 S-Series Tech 0 09-25-2008 11:56 AM
WTB: 96 DOHC Block w/crankshaft.. or crankshaft kickarse Classifieds 4 06-28-2005 05:32 PM
Wrench size - crankshaft sprocket Hiddenlites S-Series Tech 10 03-24-2005 12:27 AM
