Old 08-22-2018, 09:48 PM   #1
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
Default Headlight Sanding/Acetone Trick
Hey folks, has anyone tried this device before? Its a small stainless steel coffee cup with a heating element built in. You add acetone to the cup and when it heats up, it steams the acetone. I was dubious at first, but found one dirt cheap on aliexpress for around 9 bucks.
https://www.youtube.com/watch?v=wppa59yZjgQ
Process is: wet sand headlights with 600, then 1500 grit. Clean with water. Dry with a towel. Then apply the acetone steam (in a well ventilated area of course) and it melts/seals the surface of the plastic headlight. I am impressed, but the jury's out until I see how long it lasts. It makes snese though, the surface of the headlight is surface melted/sealed so it should last longer than a standard sand/polish.
It is much quicker than continuing to polish the headlights using standard headlight polish methods, so even if it doesn't last it is easy to repeat. The whole process took me 1/2 hour. If I do it again I will start with 400 grit as my headlights have some serious pitting that was not removed with the 600. You might be able to see in the pictures. It's definitely worth a try if you can get the cup cheap. The pictures really don't do it justice, the headlights are the shiniest part of my car, lol
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Add to Ricketts's Reputation
Rate the quality of this post and help Ricketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ricketts is offline   Reply With Quote
Old 08-22-2018, 10:26 PM   #2
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
Default Re: Headlight Sanding/Acetone Trick
I would love to try this, keep us updated please!
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-22-2018, 11:17 PM   #3
1996SW2
1996SW2 is on a distinguished road
1996SW2's Avatar
Try this next time. Took me five minutes or less for each side. I did a post on it. Still lookin good.
https://youtu.be/z2ZRKPshPVM
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 08-22-2018, 11:39 PM   #4
Ricketts
2000 SC1
Yep - basically the same thing, but your way is probably quicker. I remember watching that video before and wondering how smooth the acetone made the surface with the wipe. I am curious how long this acetone trick will last. I think it might seal the surface better...we'll see. I was going to clearcoat the end result, but it might be harder to re-do the process in the future if there are still large portions of clearcoat still attached to the headlight.
It was a fun experiment for sure. Cool to watch the headlight surface become clear almost by magic
Old 08-26-2018, 01:21 PM   #5
DIYguy
DIYguy's Avatar
Happy Re: Headlight Sanding/Acetone Trick
I use acetone vapor polishing on 3D printed ABS parts all the time.
It can make them positively glossy and even wet-looking.
But to be perfectly honest I had not thought of doing it to headlights.
Very interesting.
I have used "wheel clear coat" paint on headlights after 2000 grit wet sanding and it has generally held up quite well.
https://www.autozone.com/paint-and-b...int/465716_0_0
The next time I have to clean up some headlights I will try your method for sure.
DIYguy
Quando Omni Flunkus Moritati
97SC2 Saturn (gone but never forgotten), Gen6 Camaro, Cruze Eco, Chevy SS P/U, Honda VT1100C, Honda CBX
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-26-2018, 01:47 PM   #6
MikeNW
MikeNW's Avatar
1997 SL
Interesting.
I did use spray clearcoat on my wife's L200 (sold) headlights. after a while, it cracked and yellowed and peeled. Probably the mind-numbing humidity down here didn't help either. Or user error, I am the worst rattle can painter.
My 21-year old S headlights are doing fine. I kept it garaged much of its summers.
08 Burgman 400
Add to MikeNW's Reputation
Old 08-26-2018, 02:10 PM   #7
cgg17
cgg17's Avatar
I did the trick, it worked well, and my visibility has improved greatly.
Old 08-30-2018, 07:17 PM   #8
toggenburg
toggenburg's Avatar
I had done this previously, but watched this video.
The guy warns not to swipe acetone a second time....with good reason.
I had one light wiped and it was crystal clear, on the other headlight, I thought I'd missed a spot and redabbed it with a fresh acetone wipe...huge mistake!
It got super cloudy, and i dabbed again and it looked like it was sclerosis of the finish. Could not get it clear again until I used one of those power drill sanding discs and had to literally sand it all off and redo. Fortunately it finally came clear.
Lesson learned, don't go back over it a second time.
Old 08-30-2018, 10:42 PM   #9
Eiron
Eiron will become famous soon enoughEiron will become famous soon enough
Eiron's Avatar
1999 SW2
Am I the only one who thinks heating acetone is a really, really bad idea?? Flash-point of 0°F ??
He's dead Jim!
You grab his tricorder, I'll get his wallet.
Add to Eiron's Reputation
Rate the quality of this post and help Eiron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eiron is offline   Reply With Quote
Old 08-30-2018, 10:53 PM   #10
Getting it to flash is not that difficult but low temperature heating to produce a vapor stream is not that dangerous as long as it is done in a well ventilated area without a source of ignition. There should also be no wind or fans as the vapor has to reach the lens in a more or less even fog.
Not a process for the inexperienced though.
Old 01-27-2019, 08:59 PM   #11
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
I had to replace a headlight bulb in my wife’s pacifica today. The lenses were cloudy so I figured I would try polishing the lenses. After some online research I went to the local AutoZone and the counter guy steered me toward trying what he does. So an $8.99 bottle of Meguiar’s PlastX plastic polish (made for polycarbonate lenses) and a $4.99 trio of terry shop towels later I had a pretty good result. I used elbow grease instead of a drill with a polishing head (like the Autozone guy uses). Knowing that there’s no protective coating I chose to cover them with some ‘work’s on any automotive surface style liquid ‘wax’ substitute That’s been in my garage for at least a decade. First I did the Pacifica and then the SW2.
https://www.meguiars.com/automotive/...0-10-oz-liquid
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 01-28-2019, 08:36 AM   #12
onlinebiker
Seconds on Meguiars...
I haven't found it in years - but I bought a BMW R90t that had a windshield that was yellowed and nearly opaque.
I spent less than 30 minutes on it, and it looked great.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Sanding the "Saturn" on the rear fascia 98SatSl2 S-Series General 6 11-19-2015 02:26 PM
acetone proneto911 S-Series General 4 05-03-2010 10:22 AM
Acetone for better MPG? bgsneeze Ion General 10 05-21-2008 05:45 PM
Acetone users poorboy S-Series Tech 5 03-31-2006 12:23 PM
Acetone in Gas oldgoat S-Series General 16 09-30-2005 03:11 PM
