Old 03-26-2017, 09:04 PM   #1
macantley
macantley is on a distinguished road
Default 2008 saturn Aura, sitting for 2 years, hasnt been started in over a year...
any things i should check for right off the bat before i even attempt starting it? it was running fine when parked, Owner lost license and parked it until the city said to move it, or they would tow it.
Add to macantley's Reputation
Rate the quality of this post and help macantley reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macantley is offline   Reply With Quote
Old 05-10-2017, 03:06 PM   #2
jimmyfloyd
jimmyfloyd is on a distinguished road
2007 AURA XR
Default Re: 2008 saturn Aura, sitting for 2 years, hasnt been started in over a year...
Check the Fluids and make sure they are full. Brakes may be rusty, so move slowly at first.
Add to jimmyfloyd's Reputation
Rate the quality of this post and help jimmyfloyd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimmyfloyd is offline   Reply With Quote
Old 05-11-2017, 12:28 PM   #3
Fuel may become stale, increasing starting time until the engine sputters to life. Fill the tank as soon as the car runs. The battery may be completely dead and not rechargeable, requiring either a boost or new battery. Once the engine fires up, the alternator takes over and tries to charge a dead battery, straining it. Oil may need to be changed. The serpentine belt may have set and delaminate at any time from dry rot. Cars like being used and not sit on the street, lawn or driveway. Tires may develop a flat spot from sitting a long time and dry rot, cracking sidewalls are hints. As mentioned, test brakes with small movement before driving away since rotors rust in place and need the initial brake application to scrape away surface rust. If severe, new rotors and pads are needed along with brake fluid replacement.
Old 06-19-2017, 07:49 PM   #4
macarose
macarose is on a distinguished road
1) Check all the fluids and the tire pressure
2) Use quality jumper cables or you may be stuck for a while.
3) When you get a full tank of gas, use some fuel system cleaner.
4) Do not go on any long drives for the first week or so. Short term drives should easily be able to show what needs attention.
5) Check the history and catch up on maintenance. The oil change will be automatic, but you may need other services as well.
Good luck!
Add to macarose's Reputation
Rate the quality of this post and help macarose reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macarose is offline   Reply With Quote
Starting car after sitting 3 years KimaX L-Series General 1 03-05-2012 01:56 AM
1994 sw1 a/c not working, hasnt worked all year bucky katt S-Series Tech 6 12-08-2009 12:28 AM
92 Sl2 saturn sohc been sitting for 3 years altean S-Series Mods 4 11-24-2009 09:09 PM
Bought a brand new 2008 Aura last night - bad things started already Humy Aura General 24 11-15-2008 09:46 AM
OT: I have a car that's been sitting for 5 years 1991SL Miscellaneous Tech 9 07-21-2003 11:20 AM
