Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 06-29-2003, 04:14 AM   #1
DualCamCoupe
DualCamCoupe is on a distinguished road
DualCamCoupe's Avatar
Question Safe way to remove rust from exhaust header?
Is there a safe way to get that nasty looking rust off my exhaust header?
Also, the plastic fluid reservoirs are a little stained. Any ideas on those?
Add to DualCamCoupe's Reputation
Rate the quality of this post and help DualCamCoupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DualCamCoupe is offline
Old 06-29-2003, 02:22 PM   #2
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default
I've actually steel wooled them and used some Simple Green to remove the excess crud. You could probably use brake cleaner to get a little more aggressive but watch out for the paint. Not too long after the header heats up, it will start turning that light red color again. So, you may want to jet coat it.
I like the red tinge because it keeps the smog goofballs from raising an eyebrow.
Add to SLeepr's Reputation
Rate the quality of this post and help SLeepr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLeepr is offline
Old 06-29-2003, 09:15 PM   #3
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
Default
Sandblast it.
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
Add to bennett9000's Reputation
Rate the quality of this post and help bennett9000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bennett9000 is offline
Old 06-30-2003, 07:59 AM   #4
SilverNickelQC
SilverNickelQC is on a distinguished road
SilverNickelQC's Avatar
2004 ION-3 Quad Coupe
2001 L-Series 3.0L Sedan
Default
I don't know about the hearders but for the plastic reservoir Fantastik takes the gunk rright off.
Add to SilverNickelQC's Reputation
Rate the quality of this post and help SilverNickelQC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilverNickelQC is offline
Old 06-30-2003, 03:03 PM   #5
Qlara
Qlara's Avatar
Default
It's tough not to get rust on the exhaust header. The whole unit is a cast-iron block......so unless you invest into aftermarket stainless steel header, that's the way it is on the stock unit.
Add to Qlara's Reputation
Qlara is offline
Old 07-02-2003, 11:37 AM   #6
GreyDuck
GreyDuck is on a distinguished road
GreyDuck's Avatar
1992 SL2
Default
You should buy a new aftermarket one...
Brian
2001 Ford Focus ZTS
1992 Saturn SL2
Go UofL Cardinals!
Add to GreyDuck's Reputation
Rate the quality of this post and help GreyDuck reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GreyDuck is offline
Air dam - Safe to remove? Cortana S-Series General 41 08-15-2007 07:21 AM
Exhaust header Tank_Takahashi S-Series Mods 7 02-06-2007 10:37 PM
How-To: Using Electrolysis to remove rust RangerRover S-Series General 22 01-03-2007 07:54 PM
Did your HKS Exhaust rust too? sc288203 S-Series General 2 02-26-2006 10:12 AM
91 exhaust header? 94sc2boy S-Series Mods 4 02-28-2001 12:34 PM
