Old 12-07-2015, 08:11 PM   #1
Faisal
Faisal is on a distinguished road
Default Help w/ p0315 , p0010 p0013 p0114 p0449
Can someone tell me if these codes can be fixed with one replacement of the Cam shaft? or the crank shaft? Can someone please give me any type of advice would help. For Saturn Aura 2008 XE 2.4L
Add to Faisal's Reputation
Rate the quality of this post and help Faisal reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Faisal is offline   Reply With Quote
Old 12-08-2015, 06:26 AM   #2
Default Re: Help w/ p0315 , p0010 p0013 p0114 p0449
Camshafts and crankshafts are part of a major engine overhaul if engine damage occurred. Is your engine damaged from a crash? If not, did you try googling for each error code? As a general rule, camshafts and crankshafts don't fail.
Some history of your car may help unless you like playing twenty questions. Mileage, maintenance done, parts replaced? And what symptoms are showing that doesn't seem normal? Did you try searching past threads for other members with the same error code(s)?
check engine light code p0013 Dobrosky92 2008 Vue 5 04-10-2018 07:00 PM
p0010 p0013 p0014 diagnosing Ander Aura General 5 04-10-2015 09:12 PM
P0315 and CHNG OIL ryan_ion Ion Tech 4 02-26-2015 05:24 PM
Diagnostic Codes P0010 & P0013 iynocerus 2008 Vue 1 09-05-2014 11:43 PM
P0013, P0014 Codes 2008vueXE 2008 Vue 3 09-16-2012 08:17 PM
