Old 10-02-2015, 06:07 PM   #1
03232001
03232001 is on a distinguished road
Default crank position for timing without removing the timing cover
I was looking to check timing on my 1995 s-series Saturn. I pulled the valve cover and the cam sprockets are aligned still.
Can anyone tell me the position of the crank pulley(HB) for timing.
I was trying not to pull the timing cover off.
I cant find it in the manual only for the sprocket with cover removed.
Thanks all
Add to 03232001's Reputation
Rate the quality of this post and help 03232001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
03232001 is offline   Reply With Quote
Old 10-02-2015, 06:22 PM   #2
Default Re: crank position for timing without removing the timing cover
Search is your friend. Follow the instructions to line up the mark and rim notch. The intake and exhaust will be slightly retarded if the chain and guides are well worn.
http://www.saturnfans.com/forums/sho...37&postcount=2
Old 10-03-2015, 08:36 AM   #3
03232001
Thank you OldNuc for the link. I actually did try searching first but I guess I wasn't using the right combination of search words cause I couldn't find anything near what I was needing to know.
You mention the mark on the crank sprocket, but that's only visible with the cover removed right??
I was hoping to know the orientation of the crank pulley to the crank sprocket to use that as my reference mark so I didn't have to pull the cover.
Pulling the cover for the valves is easy I was hoping not to have to pull the timing cover though.
Old 10-03-2015, 08:40 AM   #4
NO, it is external, there is a raised bar on the cover at 1200 and a cut in the pulley rim face at the belt, also external.
If you are buying into the hillbilly hype that the engine has jumped time that is near mechanically impossible on the 98 and older DOHC. Guide failure will however get you seriously retarded on the intake and exhaust. Running is impacted at about 1 roller worth of retard so any real problem is obvious.
Old 10-03-2015, 09:09 AM   #5
03232001
Once again I thank you OldNuc. I just needed the second opinion to re-inforce what I was already thinking.
When I pulled that valve cover and saw how tight that chain and cam sprockets were my initial thought was no way this could have jumped. Then when I looked at a video of how the guides and tensioner are installed I see room for jumping is nearly impossible.
I'm on my way out now to pull off the passenger side tire and check the lower marks. but in your opinion can wear or slop in the chain be so bad as to not allow it to start??
Old 10-03-2015, 09:41 AM   #6
Not likely. Might as well check at this point and then go read your other thread.
Old 10-03-2015, 12:01 PM   #7
J N Winkler
J N Winkler is a jewel in the roughJ N Winkler is a jewel in the roughJ N Winkler is a jewel in the rough
This is a side question: if the crank pulley has to be removed as part of other servicing (e.g. timing chain replacement), is there something that ensures the timing marks end up in the correct places when the pulley is reinstalled and the bolt is re-torqued?
Add to J N Winkler's Reputation
Rate the quality of this post and help J N Winkler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
J N Winkler is offline   Reply With Quote
Old 10-03-2015, 12:18 PM   #8
billr
There is a shaft-key between the pulley and crank, the pulley will only go on in the correct position (unless you don't put in the key!).
Add to billr's Reputation
Old 10-03-2015, 02:15 PM   #9
The timing system runs at 1/2 engine RPM and the crank key is up with pistons #1 and #4 full up. This along with the locating pins on the cams insures that everything is in the correct TDC position with #1 on TDC. This assumes that the chain is installed correctly and this is not always the case and I have seen lower sprockets with the keywqy broached about 5 degrees off from TDC.
Old 10-03-2015, 06:59 PM   #10
03232001
Thanks to all I went over and double checked everything and timing was still on point. You were correct OldNuc the cams were a smidgen off due to chain wear but nothing that should not allow this motor to fire.
Once I hit the crank pulley with some brake cleaner I was able to see the mark on the timing cover and the one on the pulley and line them up easily.
I will add to my other post my findings they are not good
Removing timing cover.. seal tool? cormor S-Series Tech 14 08-11-2014 12:00 AM
removing head without timing cover rv93 S-Series Tech 13 04-05-2013 06:59 AM
Tool to remove cams without removing timing cover SC2-0220 S-Series Tech 5 11-15-2012 12:25 AM
Spark arc's from Crank pulley to Timing Chain cover ayeayemate S-Series Mods 1 05-07-2011 01:35 AM
Trouble removing timing cover junker S-Series Tech 8 06-17-2008 02:14 PM
