Old 06-14-2003, 08:17 PM   #1
dubber
dubber is on a distinguished road
Arrow where to find exhaust bracket
got a 95 SL1 and the exhaust bracket broke. the stealership is an hour away and probably expensive.
are there any oem saturn websites to find a part like this?
Add to dubber's Reputation
Rate the quality of this post and help dubber reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dubber is offline
Old 06-14-2003, 08:50 PM   #2
ProDarwin
ProDarwin is on a distinguished road
Default
Which part? If it was the rear muffler strap, replace it with some hose clamps.
-Travis
Add to ProDarwin's Reputation
Rate the quality of this post and help ProDarwin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ProDarwin is offline
Old 06-14-2003, 10:07 PM   #3
dubber
Default
the top part of the bracket.
dubber is offline
Old 06-15-2003, 11:21 AM   #4
amazinghl
Default
Junkyard!
I just got mine yesterday. It costed me $10.
Or you can go to home depot and make your own bracket.
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 06-15-2003, 12:52 PM   #5
Jokerz93SL2
Jokerz93SL2 is on a distinguished road
Jokerz93SL2's Avatar
1993 SL2
Default
Your local parts store should be able to get ahold of one. In fact yesterday I was checking out the cost of all the exhaust parts (hangers included) on my 93 SL2, we could get ahold of all of them within 2 days where I work. Advance Auto Parts. Similar stores should be able to get them. I forget the exact price of the hangers though....maybe $10?
Good luck.
~J
Add to Jokerz93SL2's Reputation
Rate the quality of this post and help Jokerz93SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jokerz93SL2 is offline
Old 06-17-2003, 12:07 AM   #6
Qlara
Qlara's Avatar
Default
You need to buy two parts (no parts#, sorry!) from the stealership if you want to do it right with less hassle:
1 Muffler Strap + Bolt
1 Muffler L-shape Hanger bar + Bolt
Everything costs about $30 something....
The trip you spent to Saturn will save you more time to do custom work just to fit that wedge-shape muffler. Also, only the OEM strap and bar can hold the muffler tight without rattle.
Add to Qlara's Reputation
Qlara is offline
Old 06-17-2003, 02:14 PM   #7
LoveMySL1s
LoveMySL1s is on a distinguished road
Default
I have had good luck on both my SL1's with removing and replacing the metal part through the rubber block with a stainless hose clamp, and then replacing the muffler strap with a piece of 3/4 inch wide aluminum strap and stainless bolt from the local building supply store. The only caution is to not bend the aluminum strap with too short of a radius at the "bolt tightener gap" or it will snap.
It's a shame that the stainless exhaust system doesn't include stainless steel hangers and straps.
Add to LoveMySL1s's Reputation
Rate the quality of this post and help LoveMySL1s reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LoveMySL1s is offline
Old 06-17-2003, 05:50 PM   #8
Craig
Craig is on a distinguished road
Default
I thought the same thing when I installed my Borla muffler a few years back...so I made up a stainless steel mounting arrangement. I had some .060" T304 sheared to a 1" width for the band and a couple pieces of .125 T304 to make up the yoke that goes into the rubber mount. Some stainless steel bolts finished it off.
Add to Craig's Reputation
Rate the quality of this post and help Craig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Craig is offline
Old 06-18-2003, 06:25 PM   #9
Qlara
Qlara's Avatar
Happy
I agree!
However, it's pretty amazing to see the exhaust pipe + Muffler out-lasting the strap and bar too.
No rust on the muffler shell, while the whole strap has been corroded to pieces.....very cool to look at.
Qlara is offline
Extra exhaust bracket on 1994 SL2? adetroiter S-Series General 4 06-16-2009 02:08 PM
Exhaust bracket troubles Elementkng20 S-Series Tech 0 06-28-2007 01:09 PM
Part # Req: Exhaust bracket cris_thomas S-Series Tech 4 06-19-2005 10:31 AM
tough exhaust leak to find eljefino Miscellaneous Tech 4 12-24-2003 03:07 PM
help, i'm trying to find a full exhaust pic... amazinghl General Saturn Discussion 4 02-07-2003 06:59 PM
