Closed Thread
Old 06-10-2003, 08:52 AM   #1
dancingator
dancingator is on a distinguished road
Default alternator going
My alternator has started whining. I checked it with a stethoscope. It still has plenty of ampage though. My questions are:
1. The Chilton says to use a certain thin wrench to hold the nut next to the battery terminal connection, it also discusses the B+ terminal: How do you guys deal with this situation? I don't have such a wrench.
2. Generally how long is left in it if its making noise.
3. It looks easy (right or wrong)?
Thanks
Add to dancingator's Reputation
Rate the quality of this post and help dancingator reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dancingator is offline
Old 06-10-2003, 09:20 AM   #2
DualCamCoupe
DualCamCoupe is on a distinguished road
DualCamCoupe's Avatar
Default
If you're willing to consider aftermarket, a lot of people on this board have had good luck with Duralast Gold alternators from Autozone. They come with a lifetime warranty, which understandably GM alternators don't.
Add to DualCamCoupe's Reputation
Rate the quality of this post and help DualCamCoupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DualCamCoupe is offline
Old 06-10-2003, 11:22 AM   #3
bbarbulo
bbarbulo is on a distinguished road
Default
I replaced mine, it's easy... actually, I'm doing two more saturn alternators tonight... I used Bosch remanufactured OEM units (reman by Bosch...) Mine whined the whole winter, and only went in the mid spring... so 3-4 months mine took to die totally. (results may vary )
Add to bbarbulo's Reputation
Rate the quality of this post and help bbarbulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbarbulo is offline
Old 06-10-2003, 12:15 PM   #4
dancingator
Default
That's good to know. I don't need to rush. I read another post that said to use a Tappet Wrench for the battery terminal connection to the alternator. This requires a purchase by me, any ideas for that part?
Old 06-10-2003, 02:19 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
Default
if it's whistling then the countdown has started. the last time mine made the death whistle it barely had enough in it to get me to the saturn retailer, where it died in the service bay. they had to push it around to get it to the lift so they could replace it. hopefully you have a manual transaxle so it doesn't need the battery to shift gears.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 06-11-2003, 08:49 AM   #6
dancingator
Default
Did the alt. last night. $130 DuraGold at Autozone. I am sure my old alt. will be rebuilt and make someone happy. The old one sure had a squeal even after I sprayed and lubed it good. About 2-2.5 hrs total. No surprises. I didn't use a tappet wrench but I was very careful not to turn the shaft or overtighten the battery terminal nut. 89 inch-lbs is not much torque.
Old 06-11-2003, 04:02 PM   #7
Twin_Cam
Twin_Cam is on a distinguished road
Twin_Cam's Avatar
2000 SL2
Default
Okay, if I buy one of those remanufactured or aftermarket alternators, would Saturn install it for me, or would I have to go to a shop? It looks like a reasonable difficult job, and I'm not good with.......well, working on my car. It took me two and a half hours to do the serpentine belt, idler pulley, and upper motor mount. How much do you think it would cost to have someone do it?
I'm pretty sure mine's dying. It whines more when I have lights on, and today I had the air on and it was audible over my music, so I'm very sure it's the alternator and not something else.
'00 SL2m- DD, 186K miles
'05 Honda CR-V- wife's DD and my upright bass hauler
'84 Honda CB650SC Nighthawk- toy
Add to Twin_Cam's Reputation
Rate the quality of this post and help Twin_Cam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Twin_Cam is offline
Old 06-11-2003, 04:11 PM   #8
DualCamCoupe
Default
I'd recomend you just take it to an independant garage that will install one with a lifetime parts warranty.
Old 06-11-2003, 06:40 PM   #9
dancingator
Default
My quote was for $280. I am betting 2hs of labor. With your newly found background you should do it. The hardest part was taking the tire off. You know how to deal with the belt now - so thats good. The alt was held on by two bolts. Just be careful when tightening the battery terminal nut. And that is all to it. My Chilton manual described it exactly. I don't know about you but I don't make $80 an hour.... So it may be worth the hastle.
Old 06-11-2003, 10:52 PM   #10
ssicarman
ssicarman's Avatar
Default
Mitchell flat rate time to replace the alternator is 1.1 hour.
Add to ssicarman's Reputation
ssicarman is offline
Closed Thread
Alternator on the way out? AnotherSaturn L-Series General 1 03-25-2007 12:10 PM
Alternator DRAGwagON S-Series Tech 5 09-18-2006 02:33 PM
alternator a104u2nv Ion Mods 9 05-28-2006 02:10 PM
Alternator gone? 2 JS593 S-Series General 6 12-02-2005 03:31 AM
Alternator gone? JS593 S-Series General 0 12-01-2005 08:46 PM
