Old 10-20-2014, 01:15 PM   #1
TheSilverSaturn
TheSilverSaturn has a spectacular aura aboutTheSilverSaturn has a spectacular aura about
2008 Astra XE
2008 VUE 2.4L
Default Back Catalytic Converter Needed for Inspection?
Hello,
My Front Exhaust Manifold / Catalytic Converter was clogged up like a wet rag in a toilet - I cleaned that out on my own - Car still had no acceleration - I took it to a mechanic - he found the "Back Catalytic Converter" was also clogged. He scoured it out to get the car running again... Inspection time is now upon me next month. I already sourced a new/used front Manifold from a junk yard (label 18 in the link below) I can't even find the back listed as a "converter" anywhere; I guess its just part of the Exhaust Tube (cylinder between labels 13 & 21) As they only do an OBD2 read as part of the North Carolina Inspection...In everyone's much more qualifed opinion(s)Should i even bother with the expense of cutting and clamping / welding in a new back CAT??
Thanks Very Much!
http://www.tonkinonlineparts.com/sho...ssembly=811470
Add to TheSilverSaturn's Reputation
Rate the quality of this post and help TheSilverSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheSilverSaturn is offline   Reply With Quote
Old 10-20-2014, 07:27 PM   #2
phatfire6
phatfire6 will become famous soon enough
phatfire6's Avatar
2008 Astra XR
Default Re: Back Catalytic Converter Needed for Inspection?
The rear cat is part #14. Super easy to replace it with an aftermarket piece. Does your car need to pass emissions? The rear catalytic converter is not used by the computer to throw a code, so your car doesn't actually need it to run correctly. Replace it with what you choose: aftermarket cat, or false cat. These parts aren't the correct ones, just examples of what to use.
Aftermarket:
http://www.summitracing.com/parts/mpe-53103/overview/
False:
http://www.jnztuning.com/product_inf...850e8e6a6a4547
Add to phatfire6's Reputation
Rate the quality of this post and help phatfire6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phatfire6 is offline   Reply With Quote
Getting catalytic converter deleted. Input needed. Jaybrogs S-Series Mods 10 05-09-2013 04:29 PM
Catalytic Converter help! saturnmommy S-Series Tech 11 11-11-2012 08:04 PM
Failed Inspection 2001 L200 catalytic flyphoto L-Series Tech 11 03-09-2009 12:14 PM
Catalytic converter help needed JerryHughes S-Series Tech 13 12-25-2007 12:28 AM
Catalytic converter? acit_marcl L-Series General 2 06-07-2006 02:40 AM
