Old 01-20-2014, 09:35 PM   #1
vanish72
vanish72 is on a distinguished road
Default 3.0 tps relearn
Hi guys, I have a 3.0 vue and I`m wondering if someone can tell me, when you do a throttle position sensor relearn should it open the butterfly flap in the tps to wide open position during the process? Thanks.
Add to vanish72's Reputation
Rate the quality of this post and help vanish72 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vanish72 is offline   Reply With Quote
Old 01-21-2014, 12:07 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 3.0 tps relearn
I don't think so - according to FSM the throttle blade is moved to full closed at key on and will then move to an estimated optimum idle position.
Here's extract for NORMAL throttle operation:
Normal Mode
During the operation of the TAC system, several modes or functions are considered normal. The following modes may be entered during normal operation:
o  Minimum pedal value--At key-up the ECM updates the learned minimum pedal value.
o Minimum TP values--30 seconds after key-up the ECM updates the learned minimum TP value.
o In order to learn the minimum TP value, the throttle blade is moved to the closed position.
o Ice break mode-- If the throttle is not able to reach a predetermined minimum throttle position, the ice break mode is entered. During the ice break mode, the ECM commands the maximum pulse width several times to the throttle actuator motor in the closing direction.
o  Battery saver mode--After a predetermined time without engine RPM, the ECM commands the battery saver mode. During the battery saver mode, the TAC module removes the voltage from the motor control circuits, which removes the current draw used to maintain the idle position and allows the throttle to return to the spring loaded default position.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 01-21-2014, 11:43 PM   #3
vanish72
Thanks far2grumpy!
crank relearn ddeuces22 S-Series Tech 16 11-15-2013 01:01 AM
ECM relearn help please fast5thgen Vue Tech 5 11-20-2010 10:08 AM
PCM Relearn and P0172 KCdave S-Series Tech 13 03-08-2009 01:54 PM
PCM relearn candidate? John G in CT S-Series Tech 11 01-29-2009 09:09 PM
Passlock relearn... (optional relearn) austin71184 S-Series Tech 2 05-31-2006 05:51 AM
