Old 12-12-2013, 02:33 AM   #1
xXSaturnManXx
xXSaturnManXx is on a distinguished road
xXSaturnManXx's Avatar
Default intake manifold?
I looked it up and I don't see to many intake manifolds. I was curious what the best intake manifold (most air flow) for a 99 SL2, also I want it to bolt on.
Car Audio For Life
Add to xXSaturnManXx's Reputation
Rate the quality of this post and help xXSaturnManXx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xXSaturnManXx is offline   Reply With Quote
Old 12-12-2013, 08:39 AM   #2
Default Re: intake manifold?
Probably the one that is on the car now.
Old 12-12-2013, 11:02 AM   #3
SL19302
SL19302's Avatar
2002 SL1
^^^Exactly
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 12-12-2013, 01:01 PM   #4
xXSaturnManXx
ok thanks. also is the stock manifold aluminum? like can it be polished to a shine?
Car Audio For Life
Old 12-12-2013, 01:42 PM   #5
It's not standard aluminum, you can make it shiny with powder coating or some other paint job...I don't think it'll polish up on it's own.
If you want to experiment with another one, only one you can use is from another '99, bolt pattern is different '91-'98 and '00-'02 use one made from plastic.
Old 12-12-2013, 02:12 PM   #6
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
These engine don't flow like many modern 4 cylinders. You can get some power from them with breathing mods, but nothing like you see in Japanese cars. in the quest for power, your money is probably best spent on intake piping and a lighter flywheel to wake the engine up a bit.
Truly the best way to a better Saturn is to increase the cars strengths. Suspension and tires can transform these econoboxes in to great handling, twisty road machines.
Add to cloud819's Reputation
Rate the quality of this post and help cloud819 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cloud819 is offline   Reply With Quote
Old 12-23-2013, 04:47 PM   #7
StephenRM
StephenRM is on a distinguished road
StephenRM's Avatar
Actually you can make it shine!!
http://www.evilplastic.com/94mod3.htm#polished
Add to StephenRM's Reputation
Rate the quality of this post and help StephenRM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StephenRM is offline   Reply With Quote
Old 12-23-2013, 05:57 PM   #8
Polishing aluminum is a major task and as soon as polished it must be coated with an impervious coating of which there are very few and they are expensive. Conventional lacquer is not impervious.
Old 12-23-2013, 10:27 PM   #9
moresaturn
moresaturn is on a distinguished road
moresaturn's Avatar
1998 SC1
https://www.dropbox.com/s/pe6m5j3n6j...2016.37.15.jpg
This one! Functional Ram Air
1994 SL2 - 24 Hours of Lemons Racecar
1998 SC1 - 305K miles - dead
2001 SC1 - 349K miles and counting - 1 quart per 1K miles - stock engine
Just another OEM engineer...
Add to moresaturn's Reputation
Rate the quality of this post and help moresaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
moresaturn is offline   Reply With Quote
Old 12-23-2013, 10:29 PM   #10
SL19302
SL19302's Avatar
2002 SL1
Originally Posted by moresaturn View Post
Wow a household drier outlet duckt, Just when I thought I saw everything something else pops up.
CHECK YOUR OIL!
Old 12-23-2013, 10:40 PM   #11
moresaturn
moresaturn's Avatar
1998 SC1
It's in the spirit of Lemons...
Old 01-01-2014, 06:35 PM   #12
Yerboogieman
Yerboogieman is on a distinguished road
Yerboogieman's Avatar
1993 SC2
A coworker had a really nice intake manifold on his Accord, I was thinking of getting one similar and TIG welding on a Saturn Flange for the hell of it when I get some cams made.
93 SC2 M/T 224k Power Everything! :D
94 SL2 A/T 274k Sold to scrap
99 SC1 M/T 162k
97 SC2 M/T 102k
97 SL1 M/T 188k Sold Bad Valve
Aluminum valve covers all around
NGK plugs for all
Add to Yerboogieman's Reputation
Rate the quality of this post and help Yerboogieman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Yerboogieman is offline   Reply With Quote
Intake manifold? danhammer S-Series Mods 11 03-19-2011 05:40 PM
Intake manifold TParrish89 S-Series Tech 2 07-21-2010 02:48 PM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 12:52 PM
WTB: used intake manifold from '94 SL2 geartooth94 Classifieds 1 01-27-2004 10:40 PM
intake manifold miamisl2 Miscellaneous Tech 0 07-02-2002 11:12 AM
