Old 03-07-2013, 01:23 PM   #1
Project Saturn
Project Saturn is on a distinguished road
Project Saturn's Avatar
Default Power window removal
How do I go about removing the power window on the driver side of my '98 SC2 when it's stuck in the closed position? Note: I have both the inner and outer panels off since I'm going to be replacing the regulator.
Add to Project Saturn's Reputation
Rate the quality of this post and help Project Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Project Saturn is offline   Reply With Quote
Old 03-07-2013, 01:35 PM   #2
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Default Re: Power window removal
Will the window move at all or is it jammed tight?
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 03-07-2013, 01:44 PM   #3
Project Saturn
It is jammed tight. It won't move up or down.
Old 03-07-2013, 01:48 PM   #4
hoseppi
hoseppi's Avatar
2002 SL1
2008 Astra XE
Are you sure the problem is not the switch?
Old 03-07-2013, 01:53 PM   #5
trouttrooper
trouttrooper has a spectacular aura abouttrouttrooper has a spectacular aura abouttrouttrooper has a spectacular aura about
trouttrooper's Avatar
2000 SL2
Unscrew the 4 screws holding the motor in place. Then you can maneuver things around to get the motor and regulator arm out.
Richpin has a couple videos that shows most of this
Add to trouttrooper's Reputation
Rate the quality of this post and help trouttrooper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trouttrooper is offline   Reply With Quote
Old 03-07-2013, 01:56 PM   #6
trouttrooper
2000 SL2
With it jammed tight it will probably have some "sideways" torque on the screws. May be helpful to have a second set of hands holding the window up.
I've taken a few motors out at the junkyard with the windows up and no power to them. Wasn't that hard to do really.
Old 03-07-2013, 02:15 PM   #7
Project Saturn
I swapped one out with one from the junkyard which had the same results. My passenger window works fine.
Bad Window Switch...how raise power window before I get part? flyhop S-Series Tech 3 08-06-2012 09:44 AM
Power door locks,power window,fan for heat don't work dddaaa S-Series Tech 1 08-11-2011 11:40 AM
Door panel/Window removal help!! Window cracked! adabiri2 Aura General 1 08-04-2011 01:14 PM
power window switch removal saturnsctwo S-Series General 3 03-22-2009 10:06 PM
Driver's side power window pooped out again 99SC2; other window/sunroof fine. Help? Jens99SC2 S-Series Tech 4 11-09-2005 07:40 AM
