Old 01-12-2013, 05:59 PM   #1
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
Default Brushes for Power Window Motor 2000 SL2
The drivers side power window in our gold 2000 SL2 does not work well. The window will only go down so far and stop, needs help going up. I greased the slides but after removing the cover off the motor, discovered one of the brushes is broken. Has anyone ever heard of a replacement brushes and know the part number ? It looks like a simple solder job.. thank you
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 01-13-2013, 09:20 AM   #2
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Default Re: Brushes for Power Window Motor 2000 SL2
First of all, I would like to commend you for doing the extra work discovering the problem and trying to do the earth friendly thing. That's the path I always take (mainly because I'm a tightwad). Unfortunately, I think those brushes are going to be difficult to locate and the window motore are relatively inexpensive. You can still go semi-green by getting a used motor even though the labor used to remove one may be prohibitive. In the recycling game there is no such thing as a Pyrrhic victory.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 01-13-2013, 09:38 PM   #3
gveinot
gveinot's Avatar
2000 SL2
2000 SL2
thank you Hoseppi, it was worth a try.I see the new aftermarket are not that expensive.
Old 01-13-2013, 10:08 PM   #4
If you can locate a decent motor shop they can fix you up. Sandpaper will machine one to fit.
Old 01-13-2013, 10:44 PM   #5
gveinot
gveinot's Avatar
2000 SL2
2000 SL2
thank you OldNuc, I will check locally..!!
Old 01-14-2013, 11:30 AM   #6
Some older threads, hopefully the companies are still in business
http://www.saturnfans.com/forums/sho...d.php?t=143956
For the Valeo starter
http://www.saturnfans.com/forums/sho...=1#post1621952
for older starters, 94-mid 95
Old 01-15-2013, 02:33 AM   #7
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Unless I'm missing something, I think you missed that he's talking about power window motors, not starter motors.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 01-15-2013, 11:21 AM   #8
DIYguy
DIYguy's Avatar
Check at a hobby store (a real one, not Hobby Lobby or Michael's). I replaced the brushes in a power window motor on my wife's truck a while back using RC car motor brushes. Years later it is still working perfectly.
Take the old brush fragments with you and find the closest dimensional match you can. Adjust as necessary using a file or sandpaper.
DIYguy
Quando Omni Flunkus Moritati
97SC2 Saturn (gone but never forgotten), Gen6 Camaro, Cruze Eco, Chevy SS P/U, Honda VT1100C, Honda CBX
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-15-2013, 11:23 AM   #9
D'Oh! You're right, apologies to the OP. I should never post in haste
Old 01-28-2013, 07:20 PM   #10
gveinot
gveinot's Avatar
2000 SL2
2000 SL2
Ended up buying a new one at Amazon.com for $25. It was identical to the original. I secured the top slider to the top door frame on the outside using two vice grips. It took a few minutes to drill out the three rivets. Then I removed the inside bolts and the one at the end of the bottom track on the outside. There was easily enough room to pull the track out slightly and remove the old motor and gear box. Using the bolts that came with the new motor and a philips screwdriver drill type bit on the end of a small wrench I was easliy able to tightend all up. Took a few wiggles to get the tracks back so the bolts in the door all lined up. Added some white grease to both tracks and tested with jumper wires on the motor contacts before putting the door panels back on. The 13 year old window on a 218,000km car worked as good as new. Now my daughter will have working windows when this baby hits the road in the spring. Thank you all.
Power Window Motor beensmoked L-Series Tech 2 09-23-2010 10:48 AM
Blower motor brushes - where does this wire go? axls L-Series Tech 2 12-17-2008 11:52 PM
Wanted: Window Motor Brushes acman S-Series Tech 2 09-18-2007 04:34 PM
Power window motor help Tuner S-Series Tech 2 02-19-2007 12:09 PM
power window motor The Math God S-Series General 2 09-03-2004 08:54 AM
