Old 12-25-2012, 05:51 PM   #1
jcardzcollects
jcardzcollects is on a distinguished road
Default 94 SL2 leaking water under pulley
I have a 94 SL2 twin came and have noticed that my water reservoir is empty. I fill it and the next day it is empty and that is whether I use the car or not. Today I noticed water leaking from under the pulleys at the bottom of the engine, passenger side, and was wondering if this is my water pump or something else? I have checked the hoses and they seems to be fine with no leaks, if it is my water pump how hard is it to replace and does anyone have the procedure? Thank you
Add to jcardzcollects's Reputation
Rate the quality of this post and help jcardzcollects reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcardzcollects is offline   Reply With Quote
Old 12-25-2012, 06:02 PM   #2
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Default Re: 94 SL2 leaking water under pulley
The water pump is the most likely culprit. It's a fairly simple job. Check video on You Tube. The hardest part is removing the three bolts from the pulley.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
water pump and pulley mjoekingz28 S-Series Tech 12 08-25-2010 12:08 AM
A/C leaking at pulley RobertGary1 S-Series Tech 3 06-23-2010 08:52 PM
Water pump pulley? brandon12777 Vue General 17 04-09-2010 10:48 PM
water pump pulley bigbfarm S-Series Tech 4 07-12-2009 01:09 PM
water pump pulley help akadiddy1987 S-Series Tech 6 06-12-2008 10:27 PM
