Old 08-01-2012, 08:52 PM   #1
TeddyKGB
TeddyKGB is on a distinguished road
1996 SL1
Question Back end vibrates badly when idling in Drive
There's a general vibration about the car most of the time, but it gets bad when the car is idling in Drive. I don't feel it when the car is cold first thing in the morning, but it increases as I drive it through the day. It's annoying enough that I shift into Neutral at stops; it doesn't vibrate in Neutral or Park.
Recent repairs include the engine mounts and EGR valve; the spark plugs were replaced recently and a fuel system cleaner was run through it. None of these have changed the vibration problem.
It seems like problems like this have a million possibilities, so I'm hesitant to take it to a mechanic. Anyone care to hazard a guess?
Add to TeddyKGB's Reputation
Rate the quality of this post and help TeddyKGB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TeddyKGB is offline   Reply With Quote
Old 08-01-2012, 09:01 PM   #2
Default Re: Back end vibrates badly when idling in Drive
Timewise, if it hasn't been done already, the transmission mount is ready for replacement. Need a jack to hold up the transmission, and a 15mm deep well socket and a 10mm socket with a ~6in extension. Probably easiest with the driver side tire off but you can leave it on if you don't have or want to bother with jack stands.
Old 08-01-2012, 09:13 PM   #3
TeddyKGB
1996 SL1
I'm afraid that's not it; the side, rear, and transmission mounts were all replaced at the same time, and recently. They needed to be replaced (some of them were practically in pieces), but it didn't affect the vibration problem at all.
Old 08-02-2012, 10:11 AM   #4
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Did you check your muffler hanger? Grab the tailpipe and pull up slightly, then let it drop. If it makes a metailic sound , it is broken.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 08-02-2012, 11:20 AM   #5
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Mine does the same thing, i thinks its an exhaust pipe problem.
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 08-02-2012, 09:23 PM   #6
papoopeepoo
papoopeepoo is on a distinguished road
papoopeepoo's Avatar
2001 SC1
I had a similar issue. Check your muffler hanger. Mine was rusted through and the exhaust pipe was resting on the suspension cross member. I thought it was the rear suspension at first because it gave a clunking sound when i went over bumps.
Be careful with purchasing a muffler strap, the aftermarket straps don't fit the OE muffler.
Cables and wires almost never fail; the terminations do. -- www.prussianmotors.com
Add to papoopeepoo's Reputation
Rate the quality of this post and help papoopeepoo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
papoopeepoo is offline   Reply With Quote
Old 08-03-2012, 09:11 AM   #7
OU812
1996 SL1
My muffler is welded directly to the frame near the rear bumper so my problem
is definitely not the hanger.
Old 08-03-2012, 10:06 PM   #8
gyrlspeedrt
gyrlspeedrt is on a distinguished road
gyrlspeedrt's Avatar
Do you have a check engine light on as well? I've been having the same problem. My engine light is on and it says I have a misfire but have changed plugs, wires, egr valve, ignition coils. Wound up putting the originals(i.c.) back in since it made no difference). From a search, it could possibly be the intake mainfold gasket. Haven't had a chance to do it myself or take it to friend of mine to double check it for me or replace it...
GyrlSpeed Racing Team Performance
http://gyrlspeedracingteam.com
http://gyrlspeedracingteam.com/shop
GyrlSpeed App: https://play.google.com/store/search?q=gyrlspeed&hl=en
Add to gyrlspeedrt's Reputation
Rate the quality of this post and help gyrlspeedrt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gyrlspeedrt is offline   Reply With Quote
GPH when in neutral or when idling in drive Raysp30 S-Series Tech 1 09-15-2013 01:42 PM
Cannot get drive belt back on. gcomeaux S-Series Tech 14 01-13-2011 11:00 PM
unstable idling speed, engine shakes badly pingpang S-Series Tech 8 08-18-2010 11:02 PM
2002 SC2 Vibrates with AC on and idling in gear 2002saturnsc2 S-Series Tech 5 05-26-2010 01:39 PM
04 AWD Drive Shaft vibrates at 38+ Jldet5 Vue General 24 11-09-2004 10:19 PM
