Old 05-13-2011, 04:07 PM   #1
dyson
dyson is on a distinguished road
Default body control module
Does anyone know if I change my body control module will I have to get it reprogrammed? When I shut the car off it does not turn off the radio, any ideas on what it might be, I'm thinking body control module cause I already changed iginiton switch.
Add to dyson's Reputation
Rate the quality of this post and help dyson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dyson is offline   Reply With Quote
Old 05-13-2011, 04:13 PM   #2
Default Re: body control module
Presumably it's the 2001 car mentioned in your other post? It'd be a good idea to put your car info in your profile, so it shows up below your user name.
Gen-3 electricals are rather more complex than its predecessors, but AFAIK the radio is still just controlled by one "always on" power circuit and one that goes through the ignition switch. Is it an aftermarket radio, by any chance?
Add to madpogue's Reputation
Old 05-13-2011, 05:18 PM   #3
RobertGary1
Did a mechanic tell you that you needed to replace the BCM on your 96 Saturn?
-Robert
Old 05-13-2011, 06:21 PM   #4
'96???!? S/he has only one other post, and mentions a 2001 car there. Where did '96 come from?
Old 05-13-2011, 06:40 PM   #5
RobertGary1
Because 96 is WAY funnier than 2001 when talking about a BCM. I didn't make that up either, we've had people here before that have been told that their early gen SC's needed a new BCM.
Old 05-14-2011, 08:43 AM   #6
dyson
it is a 2001 .
Old 05-14-2011, 10:26 AM   #7
Does anyone know if I change my body control module will I have to get it reprogrammed? When I shut the car off it does not turn off the radio....already changed iginiton switch.
The bcm does not control power to the radio. As mentioned, the ignition switch provides switched 12v power for the radio. A second HOT wire is for radio memory. Swapping these two wires can cause this issue. One hint would be radio presets lost every time they're memorized; turning off the ignition and radio would remove the power for memory. In a normal configuration, the ignition switch would kill power to turn off the radio (if left on) but the always HOT second 12v wire remains to keep radio memory alive.
1-Is the radio original or aftermarket? If original, was this repaired and/or miswired? If aftermarket, was it wired correctly?
2-Replacing a ($400+) bcm to fix a radio problem doesn't make sense. New bcm's require programming from GM. Used ones retain mileage from the donor car and cannot be changed.
Body control module?? 02L300sat L-Series Tech 52 06-19-2014 08:53 PM
Body Control Module pfhobson Vue Tech 5 06-27-2010 10:50 AM
Body Control Module (BCM) HAS82 L-Series Tech 1 06-08-2009 03:20 PM
Body Control Module Mark S. L-Series Tech 3 02-13-2009 09:52 AM
Body Control Module Rick M Vue General 1 01-08-2008 10:58 AM
